nikitakiselev
Access to WIFI device in Deco X50 with Mikrotik
Tue Feb 07, 2023 10:19 pm
Hi. I fully stucked with the kid feature: I can't access to my wifi devices from my PC (LAN)
I have a Mikrotik RB2011UiAS-RM and TP Link Deco X50 devices.
I have connect them like that:
Deco X50 and Linux PC connected via LAN directly to Mikrotik
Wifi Device connected via WIFI to Deco X50.
So the question is: I can't access to the WIFI Device from my Linux PC. What settings should I add?
I can't open even Deco X50 dashboard (via http://192.168.68.1) from my Linux PC, but I can open it via any wifi device (like IPhone)
Here my `export` https://nikitakiselev.ru/editor/63e2b31c829278.01140144
Thank you.
dinosgb
Re: Access to WIFI device in Deco X50 with Mikrotik  [SOLVED]
Thu Feb 09, 2023 3:25 pm
Is it needed to have the X50 in router mode?
try reconfiguring it in access point mode, it's much easier.
anav
Thu Feb 09, 2023 4:08 pm
This is a deco issue not an MT issue, find the DECO support forums.
That being said, concur, just use access point mode on deco ( and let 2011 handle dchp for all clients )
Can the DECO handle vlan frames ??? ( smart AP??)
How many DECOs do you have just one?
If two can you wire two separate ports from the router to each one?
Egads no user manual at all.........
nikitakiselev
Thu Feb 09, 2023 8:22 pm
Thank you guys. I have switched Advanced -> Operation Mode from “Wi-Fi Router” to “Access Point” and it starts to work!
Users browsing this forum: 0xAA55, Bing [Bot], GoogleOther [Bot], laku and 38 guests
