victuk
Connect and create users via nodejs
Wed Feb 08, 2023 10:47 am
Hello, my name is Victor, a developer. I am developing a web app that needs to generate users on the router based on who is added to the site by the admin. I am having problem with connecting the backend to the router and creating users with the connection. The site's backend uses nodejs and express.
dusanmanic
Re: Connect and create users via nodejs
Sat Mar 11, 2023 12:07 am
You can connect backend via ssh or rest api. Do you know how?
XingxoYamchu
Wed Apr 12, 2023 7:04 am
you're having some trouble connecting the backend of your web app, which is built using Node.js and Express, to the router and creating users based on the admin's input.
Without more information about the specifics of the issue you're facing, it's difficult to provide a solution. However, I suggest taking a closer look at the code and configuration for both the backend and the router to ensure that they are properly communicating with each other.
Users browsing this forum: No registered users and 57 guests
