Maks2603
Low download on Wireless - Mikrotik Audiance
Wed Feb 08, 2023 7:10 pm
I am having trouble with download speed on wireless interfaces in MikroTik Audiance (RBD25G-5HPacQD2HPnD) . I get ~15Mbps download while upload gets to around ~350Mbps. It affects both 2.4GHz and 5GHz interfaces. Things I tried so far:
- Scanned wireless channel with WiFi Scan on smartphone and MikroTik scan in Audiance and it is clear in both cases
- changed RouterOS to 6.86 and 6.94 and the problem persists (currently running ROS 7.7)
- disabled WDS mesh configuration - no effect
- did factory reset to CAPsMAN and got ~150Mbps download and ~350Mbps - download is better, however I cannot keep this config becouse it uses NAT and basicly changes Audiance into router (I need AP only in same subnet)
- checked eth1 connection speed to central switch and I get entire 1 Gbps so the problem is in Audiance
- changed hardware - I have several Audiances and every one behaves the same
I really hope you can help me, it is bizzare that I cannot watch FHD video while uploading huge files to NAS in a matter of seconds. I attach my config below:
# feb/08/2023 17:46:16 by RouterOS 7.7
# software id = 41TF-41W3
# model = RBD25G-5HPacQD2HPnD
# serial number = D5840E3ED9B0
add admin-mac=2C:C8:1B:58:FB:89 auto-mac=no name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX \
    country=no_country_set disabled=no distance=indoors frequency=auto \
    frequency-mode=manual-txpower installation=indoor mode=ap-bridge \
    multicast-buffering=disabled multicast-helper=disabled ssid=LumiHOMES \
    wds-default-bridge=bridge wds-mode=dynamic-mesh wireless-protocol=802.11 \
    wmm-support=enabled
set [ find default-name=wlan2 ] band=5ghz-n/ac basic-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps channel-width=\
    20/40/80mhz-XXXX country=no_country_set disabled=no distance=indoors \
    frequency=auto frequency-mode=manual-txpower installation=indoor mode=\
    ap-bridge multicast-buffering=disabled multicast-helper=disabled ssid=\
    LumiHOME5S station-roaming=enabled vht-basic-mcs=mcs0-9 \
    wmm-support=enabled
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256
/interface wireless
set [ find default-name=wlan3 ] band=5ghz-a/n/ac channel-width=20/40mhz-XX \
    mode=ap-bridge security-profile=*1 ssid=SYNC-58FB8C
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add comment=defconf disabled=no interface=bridge
add bridge=bridge ingress-filtering=no interface=ether2
add bridge=bridge ingress-filtering=no interface=ether1
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
/ipv6 settings
add interface=bridge list=LAN
add interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 interfaces=wlan1,wlan2
/interface wireless connect-list
add interface=wlan2 security-profile=default
add interface=wlan1 security-profile=default
/ip dhcp-client
/ip dhcp-relay
add dhcp-server=192.168.5.1 disabled=no interface=bridge local-address=\
    192.168.5.6 name="DHCP Relay B"
set allow-remote-requests=yes
/ip dns static
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name="LumiHOME B (Julia)"
/tool mac-server
/tool mac-server mac-winbox
Thanks in advance !
Maks2603
Re: Low download on Wireless - Mikrotik Audiance
Mon Feb 13, 2023 4:02 pm
I managed to resolve the issue.
If someone in the future has the unfortune to have the same situation than uncheck "Unknown Multicast Flood" option in port settings at the bridge section.
I hope it helps.
seriquiti
Mon Feb 13, 2023 4:15 pm
If you have so much Multicast on your network that it makes this much of a difference then I'm confused - how many devices is on your network?
Users browsing this forum: grusu, massinia and 68 guests
