adarshharisree
CHR Hardware for PPPoE server for 2 Lakh Subscribers
Thu Feb 09, 2023 7:44 am
Hi all,
I am setting up PPPoE server for TR069 WAN, the below are my requirement details.
- 2 Lakh PPPoE concurrent users ( total 10 Lakh users distributed among 5 POPs)
- bandwidth below 50kbps per user
- No NAT
Please anyone suggest the minimum required hardware specification for the CHR Virtual Machine?
connectlife
Re: CHR Hardware for PPPoE server for 2 Lakh Subscribers
Sun Feb 12, 2023 5:25 pm
Lakh???
elbob2002
Mon Feb 13, 2023 9:52 am
Lakh means 100,000 in India.
So 200,000 concurrent users with a total of 1,000,000 users among 5 POPs is my understanding of the question.
adarshharisree
Mon Feb 20, 2023 6:46 am
Yes, you are right we have to deliver a total of 10 Lakh CPEs.
I repeat there is no NAT and also very low traffic per CPE.
adarshharisree
Mon Feb 20, 2023 6:51 am
Now I have set up a CHR with 8cores and 8GB RAM for testing. Currently, 10K concurrent sessions and the RAM usage is 1GB, and CPU usage is 20 to 30%
chechito
Mon Feb 20, 2023 7:53 am
i dont think that more than 25.000 concurrent users per BNG PPPoE server can be a good idea
You can Virtualize several of this BNG on a server capable of doing that massive task, maybe a server of 32 cores (Only real Performance cores not eficiency intel cores)
DarkNate
Wed Feb 22, 2023 9:21 pm
25.000? Decimal? You mean 25 concurrent users, or 25,000 users?
If it's the latter, yes. I agree, but a lot of operators prefer having a single box handling that many or more users. Even seen those "vBNG" companies encouraging their customers to have 60k customers on a single box. To me, that's SPOF.
KopatrikKelly
Tue Apr 11, 2023 7:27 am
Regarding the CHR Virtual Machine, the requirements may vary depending on the specific use case and configuration. However, you can refer to the official MikroTik documentation for minimum hardware requirements and recommendations for CHR virtual machine deployments.
I hope this helps!
rextended
Sun Apr 16, 2023 12:03 am
[quote=KopatrikKelly post_id=995622 time=1681187228 user_id=214094]
I hope this helps!
[/quote]
TAG: ###RCHCK###
Reason: removed excessive quotting of preceding post; be wise, quote smart. lines of quote, 1 line of post.
Users browsing this forum: No registered users and 45 guests
