dainiuv
RouterBOARD 750G r3 slow with Microsoft OneDrive servers
Thu Feb 09, 2023 9:51 am
My RouterBOARD 750G r3 is slow with Microsoft OneDrive servers and other Microsoft servers. I tried Google Drive - everything is fine.
Firmware version: 6.49.7
How can I check where is problem?
dainiuv
Re: RouterBOARD 750G r3 slow with Microsoft OneDrive servers
Tue Feb 14, 2023 1:41 pm
I have figured out that Mikrotik drops some TLS packets. How can I fix it? Or debug which setting is dropping packets?
holvoetn
Tue Feb 14, 2023 6:15 pm
First option:
Check firewall, especially the drop rules.
See which counters increase when you make connection to OneDrive.
Also check raw rules if you have those.
dainiuv
Wed Feb 15, 2023 7:18 pm
I tried to upgrade RouterOS to 7.7 version. Still the same.
Checked packets - there is some but not from Microsoft servers.
Here is firewall config:
# feb/15/2023 19:15:06 by RouterOS 7.7
# software id = CBIH-XCX9
# model = RB750Gr3
# serial number = 6F38075C6F0E
add action=accept chain=input comment="Allow OpenVPN" dst-port=1194 protocol=tcp
add action=accept chain=input src-address-list=Admin
add action=accept chain=input dst-address=88.119.197.114 dst-port=1723 in-interface=ether1 protocol=tcp
add action=accept chain=input dst-address=88.119.197.114 in-interface=ether1 protocol=gre
add action=accept chain=input comment="reikalinga VPN sertifikatui pasiimti" dst-port=443 protocol=tcp
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related
add action=accept chain=forward dst-address=172.20.45.34 dst-port=80 protocol=tcp src-address=192.168.1.0/24
add action=accept chain=forward dst-address=172.20.45.34 dst-port=80 protocol=tcp src-address=192.168.8.0/24
add action=accept chain=forward comment="Spausdinimas i\F0 EMC-Sveciams \E1 centrin\E1 spausdintuv\E0" dst-address=172.20.45.100 dst-port=515,721-731,9100-9102 protocol=tcp src-address=192.168.1.0/24 src-port=""
add action=accept chain=forward dst-address=172.20.45.100 dst-port=161,162 protocol=udp src-address=192.168.1.0/24 src-port=""
add action=accept chain=forward comment="Spausdinimas i\F0 EMC2 tinklo \E1 centrin\E1 spausdintuv\E0" dst-address=172.20.45.100 dst-port=515,721-731,9100-9102 protocol=tcp src-address=192.168.8.0/24
add action=accept chain=forward dst-address=172.20.45.100 dst-port=161,162 protocol=udp src-address=192.168.8.0/24
add action=drop chain=forward dst-address=172.20.0.0/16 src-address=192.168.1.0/24
add action=drop chain=forward dst-address=172.20.0.0/16 src-address=192.168.8.0/24
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!srcnat,dstnat connection-state=new disabled=yes in-interface=ether1
I have only default Raw rule.
Users browsing this forum: baragoon, Bing [Bot], ips, kos, NetworqAndy, sybadi, volchenok, zekino and 78 guests
