jjohnny001
Help me chose hardware for school wireless network please!  [SOLVED]
Thu Feb 09, 2023 2:49 pm
Hi
my name is john and I'm a student.
I'm trying to set up a wifi network in school to distribute wifi to students in my school hostel. I am however having issues determining the best devices to suit my needs.
I plan on covering 5 hostel blocks
each hostel block is about 66 meters long, the hostels are in parallel, hence, the total area I plan on covering is about 100m².
I plan on having up to 120 concurrent users at peak usage hours.
my main issue now are:
1. choice of router, to give me peak performance(I'm on a budget, but I need a recommendation that should get the job well done, with extra allowance)
2. method of covering the area basically if I should go with antennas; I don't know if to get an Omni directional antenna. or use access points (I do not have hands on experience on how far these can cover)
please advise.
please find attached the hostel build plan; my room is shaded in ash.
I'd appreciate your response
anav
Re: Help me chose hardware for school wireless network please!
Thu Feb 09, 2023 10:30 pm
Do your own homework!! :-)
jjohnny001
Thu Feb 09, 2023 11:01 pm
please... I've been studying Mikrotik for over a week now
at least 10 hours daily but there are things only experience can teach
all these spec sheets don't always prove true in real-world scenarios
If you can help, I'd appreciate
anav
Thu Feb 09, 2023 11:15 pm
The qualified School or school board IT section or their assigned contractor should be tasked with the job.........................
Rox169
Thu Feb 09, 2023 11:20 pm
Mikrotik do not have best WiFi....wait for device with wifiwave2, you should wait for cAP ax [cAPGi-5HaxD2HaxD] (r2)....or you may check UniFi AP with WiFi 6 standard.....
viewtopic.php?p=976889
anav
Fri Feb 10, 2023 5:25 am
Concur, Something like the RB5009 would be a decent router to use, but for wifi............... your budget will be blown to get decent performance
ConradPino
Fri Feb 10, 2023 7:28 am
MikroTik may not suit your high density environment. See MikroTik WiFi AP For CRS309 CRS326 CRS326 Fleet for experienced opinions.
gotsprings
Sat Feb 11, 2023 2:44 am
Like a whole week?
Wow!
anav
Sat Feb 11, 2023 3:23 am
Better off studying networking and wifi deployments.
ConradPino
Sat Feb 11, 2023 3:27 am
Like a whole week?
I believe it. I spent hours and hours for almost a week with L3 HW Offload bug fixes.
MT has most of the information there; it's just spread out here and there.
Some MT text doesn't make sense unless you experience it failing.
Anything sophisticated as MT products is tough the first time.
ConradPino
Sat Feb 11, 2023 3:30 am
@gotsprings, good to see you here.
anav
Sat Feb 11, 2023 3:30 pm
Oh I doubt he will waste any more time on this thread LOL.
Users browsing this forum: boocko and 26 guests
