BigCol
ROS versions - i'm confused
Sat Feb 11, 2023 5:16 pm
I've just purchased a MikroTik Cap XL. when i look in Packages, i can see i'm using 6.49.7. But i've read the latest version is 7.x??
Have i bought an old AP that won't take newer ROS versions?
Colin
BartoszP
Re: ROS versions - i'm confused
Sun Feb 12, 2023 12:45 am
https://wiki.mikrotik.com/wiki/Manual:License
All Licenses:
never expire
can use unlimited number of interfaces
are for one installation each
offer unlimited software upgrades
When you buy any computer with preinstaled software is this software always the latest fully patched version from the day of purchase?
anav
Sun Feb 12, 2023 2:53 am
My question is why did you purchase a cap XL???
aoakeley
Sun Feb 12, 2023 3:30 pm
Have you tried upgrading?
System - Packages - Check for updates
(Upgrade channel)
BigCol
Sun Feb 12, 2023 10:06 pm
I read good reviews, is it not a good device??
I would appreciate you sharing any concerns you may have...
BigCol
Mon Feb 13, 2023 10:12 am
All Licenses:
never expire
When you buy any computer with preinstalled software is this software always the latest fully patched version from the day of purchase?
Well of course i have looked in both RouterBoard and Packages and updated both, and the version i quoted in my original post is the upgraded version. However, these appear to be version 6.x and i read that 7.x is available. So I'm wondering a couple of thinks, have i bought outdated hardware that isnt capable of running the latest, or, are there different streams of code depending on the device type, i thought I'd read that all devices run the same R-OS?
Guntis
Mon Feb 13, 2023 10:21 am
Once you have the latest stable version on RouterOS v6, you should see under "check for updates" a channel called "upgrade", change the channel to it, and then you will be able to install version 7 from it. Another option is just to download the version 7 RouterOS arm package from mikrotik.com/downloads by uploading the file and rebooting the device.
BigCol
Re: ROS versions - i'm confused  [SOLVED]
Mon Feb 13, 2023 11:00 am
Thanks Guntis - i just found this :)
Colin
BigCol
Tue Feb 14, 2023 11:57 pm
Is there a problem with it?
mkx
Wed Feb 15, 2023 3:14 pm
Not really. It's just that it's a generation old ... the newest MT wireless devices are <anything> ax, e.g. cAP ax.
Users browsing this forum: Bing [Bot] and 79 guests
