M52B28
Access to local LAN network using WireGuard
Sat Feb 11, 2023 8:22 pm
Hello Everyone,
This is my first topic on this forum :)
I bought router RB4011igs+rm with OS ver,7. This router now works in my office. I launched wireguard on router and on my PC at home.
After activation vpn i can ping gateway - router in my office, I have answer, but.. that's all I can do :) I need access to local network in my office and access to my rb4011igs+rm using website.
Please tell me what should I do and.. how :) Many thanks in advance !
Below config my PC - client wireguard:
[Interface]
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=
Address = 10.11.0.3/32
DNS = 192.168.88.1
[Peer]
PublicKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx=
AllowedIPs = 0.0.0.0/1, 128.0.0.0/1
Endpoint = blablabla.net.nu:13231
PersistentKeepalive = 10
anav
Re: Access to local LAN network using WireGuard
Sun Feb 12, 2023 4:24 am
Need full config of office router.
/export file=anynameyouwish ( minus router serial number and any public WANIP information, keys etc.. )
ON PC CLIENT
If your intent is to
a. access LAN subnet on Main router
AND
b. internet through the main router the allowed IPs should only be....
AllowedIPs = 0.0.0.0/0
M52B28
Sun Feb 12, 2023 12:44 pm
Here is my router config:
# feb/12/2023 11:32:04 by RouterOS 7.7
# software id = CX3B-WEKH
# model = RB4011iGS+
# serial number = XXXXXXXX
add admin-mac=48:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=13231 mtu=1420 name=MYVPN
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=exampleuser.world
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.50-192.168.88.199
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface wireguard peers
add allowed-address=10.11.0.2/32 comment="Latitude13;3" interface=MYVPN \
persistent-keepalive=10s public-key=\
"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
add allowed-address=10.11.0.3/32 comment=Rmachine interface=MYVPN \
192.168.88.0
add address=10.11.0.1/24 interface=MYVPN network=10.11.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
established,related,untracked
add action=accept chain=input comment=Wireguard dst-port=13231 protocol=udp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=RTIK
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
aoakeley
Sun Feb 12, 2023 1:09 pm
make allowed-address 0.0.0.0/0 so any traffic can be routed over wireguard peers
And you need to add a route in for the remote subnet at both ends
e.g.
add dst-address=192.168.2.0/24 gateway=10.11.0.2
add dst-address=192.168.88.0/24 gateway=10.11.0.1
anav
Sun Feb 12, 2023 3:04 pm
Good morning,
(1) Your wireguard settings on the Router are correct.
(2) As I mentioned on my first post, the settings on the Client ( Laptop ) for the router peer should only have one entry 0.0.0.0/0
That covers off both internet traffic and any remote traffic desired to reach the subnets at the router.
If you didnt want internet then the peer settings would be
10.11.0.1,192.168.88.0/24
(3) No additional routes are required, on the router, because the router creates one automatically
<dac> dst-address=10.11.0.0/24 gwy=MYVPN
(4) Due to the nature of the firewall rules, nothing should be blocking your traffic to the subnets either.
So its a bit of a mystery at this point.
In any case we will do a few things..
(5) Add the wireguard interface as a LAN list member. Without changing firewall rules that will enable you to config the router
add interface=MYVPN list=LAN
This is due to the input chain dropping anything not coming from the LAN. With wireguard included in the LAN list, you should be able to reach the router itself for configuration purposes.
(6) On the forward chain side we will be a bit more aggressive and take the one default rule and modify it etc..........
TO:
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
What we have done is take a complex rule with implied functionality into much clearer and better security rules.
from stating drop all traffic from the WAN that is not meant for port forwarding ( and allow everything else )
We go to stating. allow internet traffic originating from the LAN, allow port forwarding, drop everything else ( allow only what we want and drop everything else )
(7) If you are still having issue after this, then I would look at windows based laptops as the problem ( w11 doesnt play nice and often they have firewalls that get in the way )
M52B28
Sun Feb 12, 2023 11:55 pm
After command: add interface MYVPN list=LAN I've got access to my router via client PC :) On client I used version without Internet by vpn (one of the option how did You help me).
Unfortunatelly I still can't connect via rdp to computers on the LAN network.
*Other commands hmm Something went wrong:
[admin@RTIK] > /interface list member
[admin@RTIK] /interface/list/member> add comment=defconf interface=bridge list=LAN
failure: already have such entry
[admin@RTIK] /interface/list/member> add interface=MYVPN list=LAN
[admin@RTIK] /interface/list/member> add comment=defconf interface=ether1 list=WAN
[admin@RTIK] /interface/list/member> add interface=ppoe-out1 list=WAN
input does not match any value of interface
[admin@RTIK] /interface/list/member> add action=drop chain=forward comment=\
expected end of command (line 1 column 5)
[admin@RTIK] /interface/list/member> "defconf: drop all from WAN not DSTNATed" con
nection-nat-state=!dstnat \
expected command name (line 1 column 1)
[admin@RTIK] /interface/list/member> connection-state=new in-interface-list=WAN
syntax error (line 1 column 17)
[admin@RTIK] /interface/list/member> add action=accept chain=forward in-interface-
[admin@RTIK] /interface/list/member> add action=accept chain=forward comment="port
[admin@RTIK] /interface/list/member> add action=drop chain=forward comment="drop a
ll else"
anav
Mon Feb 13, 2023 6:20 am
Not sure I understand what I mean, you were only supposed to add the new line not add duplicates of existing lines LOL>
M52B28
Mon Feb 13, 2023 4:07 pm
Sorry, I have no experience :) I pasted what the console returned for You to see.
What should I do now to access the LAN devices behind the router ?
anav
Mon Feb 13, 2023 4:24 pm
I need to see the updated config.
/export file=anynameyouwish ( minus router serial # and any public WANIP info )
M52B28
Tue Feb 14, 2023 8:51 pm
My config below:
# feb/14/2023 19:42:31 by RouterOS 7.7
# serial number = XXXXXXXXXXXXXXXX
use-peer-dns=yes user=example@pibiip.pl
/port
set 0 name=serial0
set 1 name=serial1
add comment="For VPN" interface=PCSVPN \
list=LAN
"ZXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx="
"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
192.168.88.0
/ip cloud
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.198 client-id=1:0:24:8c:3c:xx:xx mac-address=\
00:24:8C:3C:xx:xx server=defconf
/ip dns static
invalid
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=RTIK
/tool mac-server
anav
Tue Feb 14, 2023 9:07 pm
(1) I requested you add MYVPN to the LAN LIST INTERFACE. Instead you added PCSVPN, confused ???? Change this to
(2) Why do you have persistent keep alive setting on the Server Router for client peer. ( Its the client your home wireguard device that needs keep alive on its peers settings for the router ). They can be removed.
list=LAN
192.168.88.0
(3) You failed to change the Forward chain rules as suggested.
Replace this
WITH THIS:
add action=accept chain=forward in-interface=MYVPN dst-address=192.168.88.0/24
{ forgot to include this one last time }
M52B28
Wed Feb 15, 2023 1:29 am
Regarding point 1:
I changed PCSVPN to MYVPN only for the purpose of the forum entry to be clearer. Sorry. In my config was only PCSVPN entry.
Below my config after changes. Unfortunately, I still can't connect to devices on the LAN behind the router.
# feb/15/2023 00:20:08 by RouterOS 7.7
add admin-mac=48:A9:8A:XX:XX:XX auto-mac=no comment=defconf name=bridge
add listen-port=13231 mtu=1420 name=PCSVPN
use-peer-dns=yes user=example@blabla.pl
/port
set 0 name=serial0
set 1 name=serial1
add comment="for vpn" interface=PCSVPN \
list=LAN
add allowed-address=10.11.0.2/32 comment="Latitude13;3" interface=PCSVPN \
"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx="
add allowed-address=10.11.0.3/32 comment=Rmachine interface=PCSVPN \
192.168.88.0
add address=10.11.0.1/24 interface=PCSVPN network=10.11.0.0
/ip cloud
/ip dhcp-client
add address=192.168.88.198 client-id=1:0:24:8c:3c:7d:ff mac-address=\
00:24:8C:3C:7D:FF server=defconf
/ip dns static
add action=accept chain=input comment=Wireguard dst-port=13232 protocol=udp
invalid
add action=accept chain=forward comment="Port forwarding" \
add action=accept chain=forward connection-nat-state="" dst-address=\
192.168.88.0/24 in-interface=PCSVPN
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=RTIK
/tool mac-server
anav
Wed Feb 15, 2023 3:12 am
(1) You can remove these keep alives, they do nothing......
(2) The listening port on the wg interface is 13231.
The firewall input chain has the wg port as 13232
M52B28
Wed Feb 15, 2023 1:33 pm
Regarding Point 2:
This is the same situation like above - In my config I have only rows with port number 13232. I changed before this number for the purpose of the forum entry to make it more readable. I forgot to change this number in subsequent posts. Sorry for the confusion.
anav
Wed Feb 15, 2023 1:41 pm
Okay assuming they are correct I have no clue as to the issue :-((
a. not really a publicly reachable IP ????
b. keys are not copied correctly ?????
M52B28
Wed Feb 15, 2023 4:38 pm
Like I said - after Your help I can open router management website via client, but that's all.
I think, that maybe these networks don't have any connection to each other (10.11.0.0 with 192.168.88.0) or I have some problem with firewall rules. Please look at this last one. Many thanks in advance!
M52B28
Thu Feb 16, 2023 12:38 am
Here is my config:
# feb/15/2023 23:31:39 by RouterOS 7.7
# serial number = XXXXXXXXXXXx
/port
set 0 name=serial0
set 1 name=serial1
add comment="Bez tego nie masz access to brama poprzez vpn" interface=PCSVPN \
list=LAN
public-key="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
192.168.88.0
/ip cloud
/ip dhcp-client
/ip dns static
invalid
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=RTIK
/tool mac-server
anav
Thu Feb 16, 2023 1:15 am
Yes, two things
a. we will move rules around so they are in the correct and organized order, thought that in of itself is not the issue.
and
b. modify a key rule to ensure part of an entry that I see no longer exists..... as it has no business being there!!!
{input chain default rules}
invalid
{input chain admin rules}
{forward chain default rules}
{forward chain Admin rules}
add action=accept chain=forward dst-address=192.168.88.0/24 in-interface=PCSVPN
M52B28
Thu Feb 16, 2023 9:55 pm
Friend, remember don't let yourself be brought down to someone else's level. My problem was esset internet security on the computers behind the router. I had to add exceptions to the firewall for connecting from a different subnet. Yes, I know.. I'm ashamed :)
anav
Thu Feb 16, 2023 10:00 pm
Good day my Polish friend, I will drink a toast to your honest admission and very helpful one at that as it makes my understanding of helping others that much better.
Also of course, I should be patient as you have been patient accepting many UKR refugees and of course for supporting/promoting UKR independence long before any other european country!!
M52B28
Thu Feb 16, 2023 10:28 pm
Nice to read that you have that opinion. Especially since you're on the other side of the world. Thanks for help. All the best to you and your family!
skypeja
Thu May 25, 2023 3:35 pm
Hi, I have similar problem with accessing to the local network trought WireGuard. I think, it will bw caused by FW rules, but I'm not sure, what could be wrong. Please, can anyone check my config?
EDIT: --- PROBLEM SOLVED ----
Users browsing this forum: gabeluci, patrikg, unhuzpt, zalciukaz and 116 guests
