massinia
DLNA container
Sat Feb 11, 2023 8:55 pm
Sorry for the stupid question...
Is it possible to use a container like this with the hAP ac 2?
https://hub.docker.com/r/vladgh/minidlna/
Obviously with an ext4 formatted usb hdd.
Amm0
Re: DLNA container
Sun Feb 12, 2023 8:43 pm
Sure, if you look at "tags" and something has "linux/arm/v6", it should work – yes, assuming an external disk (or potentially ROSE).
You should be able to follow the Pi-Hole example in the docs EXCEPT...
- just use "vladgh/minidlna" as remote image.
- for the "mounts" use:
/media to your RouterOS disk path
- for env variables add:
MINIDLNA_MEDIA_DIR /media
MINIDLNA_FRIENDLY_NAME=MikrotikMiniDLNA
- for the networking, skip adding the "docker" bridge, instead just add the created VETH to the existing LAN bridge
- when creating the VETH for minidlna... use an unused IP address from your LAN (e.g. 192.168.88.8/24 and 192.168.88.1 as VETH gateway if your using default LAN), and use the Mikrotik's LAN IP address as the gateway
massinia
Re: DLNA container
Mon Feb 13, 2023 11:40 am
Thank you, it works perfectly!
I got the mount directory wrong, must be /minidlna
I can't change minidlna root_container value to B but that's another story...
EDIT: fixed with env "MINIDLNA_ROOT_CONTAINER=B"
Thanks again
Amm0
Re: DLNA container
Mon Feb 13, 2023 3:36 pm
Great!
Let us know how it goes. I'm sure you'll like not be the only one requesting this one...
One note... v7.8rc1 supports "ROSE" (see https://help.mikrotik.com/docs/display/ROS/ROSE-storage). This adds RAID and NFS/iscsi clients and servers, so your minidlna container here should be able to operate on a remote file share and/or any RouterOS connected disks can be raid'ed. This obviously become useful when your start having media files to serve over DLNA.
massinia
Re: DLNA container  Topic is solved
Mon Feb 13, 2023 4:36 pm
Unfortunately I can't use it because hAP ac2 doesn't have enough space in the flash.
Sure!
I read this guide carefully and luckily I understand how containers work.
https://help.mikrotik.com/docs/display/ROS/Container
Summing up...
I create a new VETH interface with a new IP address of my LAN
Please note that I use 192.168.11.0/24 and not 192.168.88.0/24, so change the IP address according to your LAN
I added veth1 to the main bridge
I inserted a usb hdd and formatted it in ext4 with no partitions.
I can't stand clutter so I created a folder for containers, one for container data and one for media.
I shared only the media folder with smb so everyone can add movies but no one can edit the container files.
NicoBellic
Re: DLNA container
Mon May 22, 2023 1:55 am
Hi, dear massinia!
I did everything according to your instructions, but I have a problem with permissions, if I add films via SMB.
MikroTik:/Films# ls -l
total 3047816
-rwxr-xr-x 1 nobody nobody 3117904332 May 21 22:12 Film1.mkv
It works before first reboot. And container can't started with message in log chown: /minidlna/Films/Film1.mkv: Operation not permitted
How can I fixed permissions? Why user and group nobody:nobody? I think that must be minidlna:minidlna.
massinia
Re: DLNA container
Tue May 23, 2023 9:36 am
Hi, dear massinia!
total 3047816
Hi, I specified that the files inside the container shouldn't be modified.
one folder for container data and one folder for media.
You don't need to change permissions, don't put the movie folder inside the container folder.
NicoBellic
Re: DLNA container
Wed May 24, 2023 10:41 am
Yes, I made a mistake on this point. Thank you. Now it works great.
nabus
Re: DLNA container
Thu Aug 10, 2023 7:51 pm
Help to configure. The server starts and immediately stop.
Amm0
Re: DLNA container
Thu Aug 10, 2023 8:32 pm
Check the "Logging" box, then try to start it. The log should have some clues on what's going on.
Also post the results from a ":export" at the terminal if you can.
nabus
Re: DLNA container
Thu Aug 10, 2023 9:03 pm
Log noted.Where can I watch it?
nabus
Re: DLNA container
Thu Aug 10, 2023 9:23 pm
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 7.10.2 (c) 1999-2023 https://www.mikrotik.com/
Press F1 for help
[admin@MikroTik] > export
# 2023-08-10 21:22:46 by RouterOS 7.10.2
# software id = IZLE-ES5A
# model = RBD52G-5HacD2HnD
# serial number = E5780E89B9DB
add admin-mac=2C:C8:1B:EE:86:3F auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=04:5E:A4:C9:E0:00
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=Mikro wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
ap-bridge ssid=MikroTik wireless-protocol=802.11
/interface veth
add address=192.168.88.11/24 gateway=192.169.88.1 name=veth1
/container mounts
add dst=/minidlna name=DLNA src=/usb1-part1/router-serv/minidlna-data
add dst=media name="DLNA MEDIA" src=/usb1-part1/media
/disk
set usb1 type=hardware
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
"15 634 300 416" type=partition
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/container
add envlist=DLNA interface=veth1 mounts="DLNA,DLNA MEDIA" root-dir=\
usb1-part1/router-serv/containers/minidlna start-on-boot=yes
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1-part1/tmp
/container envs
add key=MINIDLNA_MEDIA_DIR name=DLNA value=/media
add key=MINIDLNA_FRIEDLY_NAME name=DLNA value=minidlna
add key=MINIDLNA_ROOT_CONTAINER name=DLNA value=MBp
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge disabled=yes interface=ether1
add bridge=bridge interface=veth1
add interface=bridge list=LAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf interface=bridge
add interface=ether1
add address=0.0.0.0/24 comment=defconf dns-server=0.0.0.0 gateway=0.0.0.0 \
netmask=24
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1 \
netmask=24
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=masquerade chain=srcnat src-address=172.17.0.0/24
/ip smb
set enabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=veth1 type="(unknown)"
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Europe/Kiev
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
Amm0
Re: DLNA container
Thu Aug 10, 2023 9:34 pm
Well "Log" on left in winbox... or but from New Terminal easier to cut-and-paste here ;)...
/log print where topics~"container"
Amm0
Re: DLNA container
Thu Aug 10, 2023 9:38 pm
You have a typo on the VETH gateway...
/interface veth
That should be "192.168.88.1" not 192.169...
Also, you don't need the veth1 in /ip upnp, since it already part of the "bridge", it doesn't need to be listed.
/ip upnp interfaces
nabus
Re: DLNA container
Thu Aug 10, 2023 9:45 pm
[admin@MikroTik] > /log print where topics~"container"
20:21:04 container,info,debug removing files, container ea4eee61-aadc-4ebd-95e9-12559c36a670
20:31:51 container,info,debug importing remote image: vladgh/minidlna, tag: latest
20:31:54 container,info,debug getting layer sha256:487e2b03bf21cee5114358865c5f238ace7f45a96
10894c7b35f40f604c07fb1
20:32:00 container,info,debug layer sha256:487e2b03bf21cee5114358865c5f238ace7f45a9610894c7b
35f40f604c07fb1 downloaded
20:32:03 container,info,debug getting layer sha256:5860ffff0c012e63b2ae5e7fa22141c412415e7f9
ddf291acacba37d88ff2974
20:32:23 container,info,debug layer sha256:5860ffff0c012e63b2ae5e7fa22141c412415e7f9ddf291ac
acba37d88ff2974 downloaded
20:32:57 container,info,debug getting layer sha256:8070f1e72ed71395974e02b36921596c0bf8d9750
43a133345d90c9624f057eb
20:32:58 container,info,debug layer sha256:8070f1e72ed71395974e02b36921596c0bf8d975043a13334
5d90c9624f057eb downloaded
20:32:58 container,info,debug import successful, container 3dad3d6a-8426-485c-8d52-3a9b61635
6b8
nabus
Re: DLNA container
Thu Aug 10, 2023 9:48 pm
deleted veth1 в /ip upnp
changed 192.168.88.1
Amm0
Re: DLNA container
Thu Aug 10, 2023 10:11 pm
Can you hit "Start" in on the container, then grab the log?
nabus
Re: DLNA container
Thu Aug 10, 2023 10:30 pm
Does not display. Does it come out and does not start?
22:00:29 wireless,info 6A:DD:89:FC:56:65@wlan2: connected, signal strength -57
22:00:32 dhcp,info defconf assigned 192.168.88.247 for 6A:DD:89:FC:56:65
22:22:36 system,info,account user admin logged in from 192.168.88.253 via local
22:23:50 system,info,account user admin logged out from 192.168.88.253 via local
22:24:01 system,info,account user admin logged in from 192.168.88.253 via local
22:24:05 wireless,info 6A:DD:89:FC:56:65@wlan2: disconnected, received disassoc: sending sta
tion leaving (8), signal strength -57
22:24:27 system,info,account user admin logged out from 192.168.88.253 via local
22:26:08 system,info,account user admin logged in from 192.168.88.253 via local
22:27:03 system,info,account user admin logged out from 192.168.88.253 via local
22:30:06 system,info,account user admin logged in from 192.168.88.253 via local
Amm0
Re: DLNA container
Thu Aug 10, 2023 11:10 pm
Hmm. I was kinda expecting it to start after fixing the gateway. And the logs don't show anything, which is kinda strange since normally there be some error in logs AFTER hitting start...
I've seen containers be picky about changes in the VETH'sgateway... Maybe try deleting the VETH, and re-create it again with same/correct IP information, then re-assign the new VETH in the container. Then try to start again...
nabus
Re: DLNA container
Thu Aug 10, 2023 11:15 pm
Ok, I'll try tomorrow. Thank you.
nabus
Re: DLNA container
Fri Aug 11, 2023 12:01 am
I did as you advised. I deleted veth1 and reconfigured it. Everything works. Thank you so much for your help.
Users browsing this forum: No registered users and 1 guest
