hansiputz
CRS326-24G-2S+RM with 2.5GBit sfp+ possible?
Sat Feb 11, 2023 9:59 pm
Hi
Is ist possible to use 2.5G sfp+ in the router?
If yes: does anyone know wich modules are working?
Thomas
torob2
Re: CRS326-24G-2S+RM with 2.5GBit sfp+ possible?
Mon Feb 20, 2023 2:49 pm
I haven't found a single seller who guarantees that their 2.5G SFP+ modules will work with all Mikrotik products. In some cases, I read customer reviews complaining that it won't work even that the sellers offered these modules "for Mikrotik". I contacted some sellers because I'm interested, too, but some didn't reply and at least one responded that I should buy a 10G SFP+ module for Mikrotik instead.
But there was also one review from December 2022 in which a Canadian customer wrote that he had a "negotiated link speed of 2.5Gbps in CRS326-24G-2S+IN". Guess it depends on the firmware installed if you're lucky.
russelld
Tue Mar 07, 2023 11:12 pm
There are a few different articles on STH which test 2.5Gbps compatibility with SFP+ modules...
(although they focus on module speed, rather than module in specific switch compatibility... but it's a starting point...)
https://www.servethehome.com/sfp-to-10g ... ers-guide/
https://www.servethehome.com/fs-sfp-10g ... -t-option/
Also, look at: https://help.mikrotik.com/docs/display/ ... FP+modules
R
mbovenka
Thu Mar 09, 2023 12:08 am
The S+RJ10 will do everything from 10M up to 10G, 2.5G included. The machine I'm typing this on connects at 2.5G to one in a CRS305.
mada3k
Long time Member
Long time Member
Sat Mar 11, 2023 12:42 pm
The switch-chip must also support NBase-T standard. 10GBase-T/SFP+ does not imply 2.5G support. Nbase-T is an later standard.
chechito
Sat Mar 11, 2023 5:43 pm
maybe Nbase-T support is not that far from 10GBase-T
at the end 2.5g ang 5g are almost the same thing as 10gBaseT running at lower frequency
Is true that many 10G baseT devices are incompatible with 2.5g or 5g BaseT, specially those on the early ages of 10G base T
Compatibility guide gives us some ligth about the subject
https://wiki.mikrotik.com/wiki/MikroTik ... ansceivers
Of course you have better chance with MikroTik transceivers specially in this tricky case
Be aware this modules can be HOT
https://wiki.mikrotik.com/wiki/S%2BRJ10 ... l_guidance
boone60
Sun Mar 19, 2023 7:34 pm
Same issue. I have a crs305 with 2 10gb connections to my IMAC and Synology. Trying to connect 2.5gb Windows machine and the crs305 sees it for a while, but then drops it. The PC does not recognize the network/connection at all. The questions are.
Do I need a specific SFP+ to" RJ45 connector?
Special setting for the network interface on the PC?
Setting on the CRS305 at the port level?
I someone who has done this can give me with settings/hardware it would be appreciated.
boone60
Mon Mar 20, 2023 4:20 am
R
Bingo|||| Thanks
mbovenka
Mon Mar 20, 2023 12:22 pm
Works for me with an S+RJ10 in the CRS305 and an Intel I225-V (Win10 Pro) at the other end. No specific setting needed at either end; they simply autonegotiate to 2.5G.
gotsprings
Wed Mar 22, 2023 3:31 am
Using the S+RJ10 to a POE injector to feed my Wireless Access Point at 2.5G.
AidanAus
Mon Apr 03, 2023 8:45 am
Hi
If yes: does anyone know which modules are working?
Thomas
Might be worth adding what routers/switch's you are looking at, im a but transient on the form so most of the time I wont see replies but if i know what switch/routers you were looking at connecting at 2.5
I would of been happy to test it out for you :)
Might also be worth contacting your local distributor as they might be able to assist testing this for you as well.
ConradPino
Sat Aug 12, 2023 6:09 am
S+RJ10 running in CRS326-24G-2S+IN with C53UiG+5HPaxD2HPaxD partner
/interface/ethernet/monitor sfp-sfpplus1 once without-paging
                             status: link-ok
                   auto-negotiation: done
                               rate: 2.5Gbps
                        full-duplex: yes
                    tx-flow-control: no
                    rx-flow-control: no
                        advertising: 10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full,2500M-full,5000M-full
           link-partner-advertising: 10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,2500M-full
                 sfp-module-present: yes
                        sfp-rx-loss: no
                       sfp-tx-fault: no
                           sfp-type: SFP/SFP+/SFP28
                 sfp-connector-type: RJ45
  sfp-link-length-copper-active-om4: 1m
                    sfp-vendor-name: MikroTik
             sfp-vendor-part-number: S+RJ10
                sfp-vendor-revision: 2.16
                  sfp-vendor-serial: F0600396D91C
             sfp-manufacturing-date: 22-02-15
                    sfp-temperature: 81C
                 sfp-supply-voltage: 3.318V
                sfp-tx-bias-current: 0mA
                    eeprom-checksum: good
                             eeprom: 0000: 03 04 22 00 00 00 00 00  08 00 00 06 67 00 00 00  .."..... ....g...
                                     0010: 00 00 01 00 4d 69 6b 72  6f 54 69 6b 20 20 20 20  ....Mikr oTik
                                     0020: 20 20 20 20 00 00 40 20  53 2b 52 4a 31 30 20 20      ..@  S+RJ10
                                     0030: 20 20 20 20 20 20 20 20  32 2e 31 36 05 00 00 b0           2.16....
                                     0040: 02 1a 00 00 46 30 36 30  30 33 39 36 44 39 31 43  ....F060 0396D91C
                                     0050: 20 20 20 20 32 32 30 32  31 35 20 20 68 00 06 15      2202 15  h...
                                     0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     0080: 78 00 d8 00 64 00 00 00  8c a0 55 f0 88 b8 75 30  x...d... ..U...u0
                                     0090: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00d0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 0a  ........ ........
                                     00e0: 51 00 81 9c 00 00 00 00  00 00 00 00 00 00 00 00  Q....... ........
                                     00f0: 00 00 00 00 00 00 02 00  ec 04 d1 e1 34 2a 0f 00  ........ ....4*..
Users browsing this forum: Bing [Bot], svmk and 49 guests
