DoMoney
Port forwarding not working
Sat Feb 11, 2023 10:44 pm
Hi.
I have a mikrotik router 192.168.88.1 and another webserver with following ip : 192.168.88.21, also I have a static real ip address.
I was able to configure remote management of mikrotik via internet.
Now I wnat to make forwatding to webserver, like, x.x.x.x:10000 and it will forward to 192.168.88.21 80 port.
I have created a firewall rule, did everything by manual. Please see the attachments.
The web server is responding locally.
Please advice.
erlinden
Re: Port forwarding not working
Sat Feb 11, 2023 11:57 pm
My advice:
Reset your device and start configuring from scratch up. Your firewall is a joke (being polite), and you only want to do remote management through VPN.
You might even want to consider a netinstall as your device could very well be compromised.
Please read:
https://help.mikrotik.com/docs/display/ROS/Netinstall
https://help.mikrotik.com/docs/display/ ... t+Firewall
anav
Sun Feb 12, 2023 2:54 am
Once you have your new setup ready to go, the default firewall rules are your friend to start off with!
then export your config and we can go from there.....
/export file=anynameyouwish
(which router by the way?)
Users browsing this forum: No registered users and 113 guests
