mohamadreza0101
No internet ping on the router, but the devices have ping
Sun Feb 12, 2023 2:03 am
hi guys,
i have mt router rb951 .My network definition is such that a TP-Link router is connected to Mikrotik as a bridge.
There are two problems for me with this config.
1.All connected devices have internet without any problem, but Mikrotik Ping router itself does not have internet
2.I did everything to port forward, but it didn't work
# feb/10/2023 21:37:15 by RouterOS 6.47.10
# software id = *******
# model = RB951G-2HnD
# serial number = DE3*******
add name=Bridge-ether4-wlan1
/interface pppoe-client
add add-default-route=yes comment="Connect to tp-link router" \
    disabled=no interface=ether5 name=isp-name password=***** user=\
    user010101
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=HomeNetWork \
    supplicant-identity="" wpa-pre-shared-key=******** \
    wpa2-pre-shared-key=*******
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge name=\
    HomeMikrotikNet security-profile=HomeNetWork ssid=HomeMikrotikNet \
    wps-mode=disabled
add name=dhcp_pool0 ranges=\
    192.168.1.1-192.168.1.10,192.168.1.12-192.168.1.254
add address-pool=dhcp_pool0 disabled=no interface=Bridge-ether4-wlan1 name=\
    dhcp1
add bridge=Bridge-ether4-wlan1 interface=ether4
add bridge=Bridge-ether4-wlan1 interface=HomeMikrotikNet
add address=192.168.1.11/24 interface=Bridge-ether4-wlan1 network=192.168.1.0
add address=192.168.1.0/24 dns-server=8.8.8.8,4.2.2.4,1.1.1.1,185.51.200.2 \
    gateway=192.168.1.11
set servers=8.8.8.8
/ip firewall address-list
add address=192.168.1.0/24 list=LocalAddress
add action=add-src-to-address-list address-list=1888 address-list-timeout=10m \
    chain=input dst-port=1888 in-interface=isp-name protocol=tcp
add action=drop chain=input in-interface=isp-name
add action=accept chain=input src-address-list=LocalAddress
add action=masquerade chain=srcnat out-interface=isp-name src-address=\
    192.168.1.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
kevinds
Long time Member
Long time Member
Re: No internet ping on the router, but the devices have ping
Sun Feb 12, 2023 10:46 pm
Using your Mikrotik router, what are you trying to ping?
anav
Wed Feb 15, 2023 1:50 pm
Why are you using PPOE on the MT when the TPLINK is giving you a fixed private IP address?
First thing is to decide whether you want the MT to be an AP/switch or a full router.
Being behind the TPLINK router means for any port forwarding scenarios you will have to contend with double nat
rextended
Re: No internet ping on the router, but the devices have ping  [SOLVED]
Wed Feb 15, 2023 2:18 pm
On blu line on picture, is present again 192.168.1.1....
You have assigned 192.168.1.1 both to the mikrotik and the tplink?
mohamadreza0101
Thu Feb 16, 2023 12:55 am
thanks ,This problem was solved with your help
Thank you very much, dear
Users browsing this forum: amarmerk and 42 guests
