PreambleDoorpost
Trouble with Port Forwarding
Sun Feb 12, 2023 3:12 am
I am having issues with port forwarding. I know these logs have a LOT of unnecessary stuff, I've been messing around trying to get port forwarding to work.
My NAT rule packet counter goes up every time I send a ping check on it but there is never a response back.
add name=local
add name=listBridge
add authentication-types=wpa2-psk mode=dynamic-keys name=profile1 \
    supplicant-identity=""
add name=dhcp_pool0 ranges=192.168.88.12-192.168.88.254
add address-pool=dhcp_pool0 disabled=no interface=local name=dhcp1
/interface bridge nat
add action=accept chain=srcnat disabled=yes
add bridge=local interface=ether2
add bridge=local interface=ether1
add bridge=local interface=ether4
add bridge=local interface=ether5
add bridge=local interface=ether6
add bridge=local interface=ether3
add bridge=local interface=sfp-sfpplus1
set discover-interface-list=listBridge
add interface=local list=listBridge
add address=192.168.88.1/24 interface=local network=192.168.88.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=combo1
add address=192.168.88.0/24 dns-server=192.168.88.3 gateway=192.168.88.1
/ip firewall address-list
add address=192.168.88.2-192.168.88.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    not_in_internet
add action=accept chain=forward connection-nat-state=dstnat disabled=yes \
    dst-address=publicip  dst-port=3245 protocol=tcp
    dst-address=publicip  dst-port=3245 protocol=udp
add action=accept chain=forward disabled=yes dst-port=3245 in-interface=\
    combo1 protocol=tcp
add action=accept chain=input comment="accept established,related" \
add action=accept chain=input disabled=yes dst-port=46698 protocol=tcp
add action=accept chain=input disabled=yes dst-port=46698 protocol=udp
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward connection-nat-state=dstnat connection-state=\
    new connection-type="" in-interface-list=listBridge
    "Drop incoming packets that are not NAT`ted" connection-nat-state=!dstnat \
    connection-state=new in-interface=combo1 log=yes log-prefix=!NAT
    new disabled=yes dst-address=publicip  dst-port=443 \
    in-interface-list=listBridge protocol=udp src-address=192.168.88.0/24
    in-interface-list=listBridge protocol=tcp src-address=192.168.88.0/24
add action=accept chain=forward disabled=yes dst-address=192.168.88.220 \
    dst-port=443 protocol=tcp
    dst-port=443 in-interface=combo1 protocol=udp
add action=drop chain=input connection-state=invalid
add action=accept chain=input comment="allow ICMP" in-interface=combo1 \
    protocol=icmp
add action=accept chain=input comment="allow Winbox" in-interface=combo1 \
    port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" in-interface=combo1 port=22 \
    protocol=tcp
add action=drop chain=input comment="block everything else" in-interface=\
    combo1
add action=accept chain=input comment="default configuration" \
add action=accept chain=input src-address-list=allowed_to_router
add action=accept chain=forward comment="Established, Related" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
    log=yes log-prefix=invalid
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp \
    protocol=icmp
    "Drop incoming from internet which is not public IP" in-interface=combo1 \
    log=yes log-prefix=!public src-address-list=not_in_internet
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=\
    icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 \
    protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 \
    protocol=icmp
add action=accept chain=icmp comment=\
    "host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 \
    protocol=icmp
add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 \
    protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 \
    protocol=icmp
add action=drop chain=input comment="Drop Invalid connections" \
    "Allow Established/Related/Untracked connections" connection-state=\
    established,related,untracked
add action=drop chain=input comment="Drop everything else"
/ip firewall mangle
add action=passthrough chain=prerouting disabled=yes dst-port=3245 log=yes \
    protocol=tcp
add action=masquerade chain=srcnat out-interface=combo1
add action=dst-nat chain=dstnat disabled=yes dst-address=publicip \
    dst-port=443 in-interface=combo1 protocol=tcp to-addresses=192.168.88.220 \
    to-ports=443
add action=dst-nat chain=dstnat disabled=yes dst-port=443 in-interface=combo1 \
    protocol=udp to-addresses=192.168.88.220 to-ports=443
add action=dst-nat chain=dstnat disabled=yes dst-port=60665 protocol=udp \
add action=dst-nat chain=dstnat disabled=yes dst-address=oldpublicip  \
    dst-port=27765 protocol=tcp src-port="" to-addresses=192.168.88.230 \
    to-ports=27765
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.88.230 \
    out-interface=local protocol=tcp src-address=192.168.88.0/24
    dst-port=25565 in-interface=combo1 protocol=udp to-addresses=\
    192.168.88.232 to-ports=25565
add action=dst-nat chain=dstnat disabled=yes dst-port=1224 protocol=tcp \
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.88.220 \
add action=dst-nat chain=dstnat disabled=yes dst-port=1224 protocol=udp \
add action=dst-nat chain=dstnat disabled=yes dst-port=5060 protocol=udp \
add action=dst-nat chain=dstnat disabled=yes dst-port=5060 protocol=tcp \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set winbox address=192.168.88.0/24
/ip ssh
set strong-crypto=yes
/ip upnp interfaces
add disabled=yes interface=ether1 type=internal
add disabled=yes interface=local type=internal
add disabled=yes interface=combo1 type=external
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
anav
Re: Trouble with Port Forwarding
Sun Feb 12, 2023 3:21 pm
Your firewall rules are a mess.
The only forward chain rule you need for port forwarding is one rule.
The rest are done in NAT rules...............
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat
aoakeley
Sun Feb 12, 2023 3:23 pm
All the DST-NAT (port forwarding rules) are disabled
PreambleDoorpost
Sun Feb 19, 2023 10:41 pm
Here is my setup after resetting my whole router and starting from scratch. I still can't get port forwarding to work, the counter on my dst-nat rule goes up by 1 everytime I test but it's still closed on the outside.
add name=Local
add name=listBridge
add name=dhcp_pool0 ranges=10.10.22.2-10.10.22.254
add address-pool=dhcp_pool0 interface=Local name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
add bridge=Local interface=ether1
add bridge=Local interface=ether2
add bridge=Local interface=ether3
add bridge=Local interface=ether4
add bridge=Local interface=ether5
add bridge=Local interface=ether6
set discover-interface-list=!listBridge
add interface=Local list=listBridge
add address=10.10.22.1/24 comment=defconf interface=Local network=10.10.22.0
/ip dhcp-client
add interface=combo1
add address=10.10.22.0/24 dns-server=1.1.1.1 gateway=10.10.22.1
add action=accept chain=input comment="Default configuration" \
add action=fasttrack-connection chain=forward comment="fast-track for establis\
    hed,related\"This rule allows established and related connections to bypas\
    s the firewall and significantly reduce CPU usage." connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward dst-port=65472 protocol=tcp
add action=drop chain=input comment="Drop everything else, log = yes"
add action=dst-nat chain=dstnat dst-port=65472 in-interface=combo1 protocol=\
    tcp to-addresses=10.10.22.241
/ip service
set ssh port=2200
set winbox address=10.10.22.0/24
set api-ssl disabled=yes
/ip ssh
/lcd
set color-scheme=dark enabled=no
/system clock
set time-zone-name=America/Los_Angeles
set enabled=no
/tool mac-server
Sob
Sun Feb 19, 2023 11:11 pm
Are you sure that on your 10.10.22.241 device something definitely listens on tcp port 65472, it's not blocked by device's own firewall, device has this router as its default gateway, etc?
PreambleDoorpost
Sun Feb 19, 2023 11:15 pm
Default gateway = yes
I'm just using a port checker on the web so i'd say yes something is listening
not blocked by firewall = yes shouldn't be
Sob
Sun Feb 19, 2023 11:18 pm
I mean, when you're using port checker, at that moment, is there any software running on internal device and listening on that port? It must be, otherwise there will be no reponse. You can't open port "for later" without something actively using it and have it shown as open.
anav
Sun Feb 19, 2023 11:19 pm
Why did you make this rule in this format.........
You are missing LAN and WAN interfaces
add name=WAN
add name=LAN
add name=listBridge ??? but why suggest not needed....... aka remove it.
/interface list members
add interface=combo1 list=WAN
add interface=Local list=LAN
Now you can make the rule properly.
Why did you remove most of the default firewall rules.......... and why do you not get organized and at least put them within the same chain???
USE THIS.......
{Input Chain}
(default rules)
(user rules)
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
{forward chain}
(default rules)
(user rules)
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
The only weird rule which needs explanation is this rule......?? I didnt include it above as it seemed out of place.
Okay I see its related to port forwarding yES REMOVING IT was the smart move.
With the above fixed up,
In terms of port forwarding....... ( as long as you are not attempting to reach the server from the LAN using the WANIP of the router ) it should be fine.
External users should be able to connect and LAN users should be able to connect using the LANIP of the server directly.
If external users cannot reach the server then its more likely an ISP issue or a firewall on your server device or you dont have a publicly reachable WANIP.
Last config bit seen.
/tool mac-server
PreambleDoorpost
Sun Feb 19, 2023 11:56 pm
wouldn't the port checker online be doing just that, what's the point otherwise?
Sob
Mon Feb 20, 2023 12:05 am
You need to understand what it does. There may be misleading wording about checking for open ports. But it's actually checking if it's able to connect to something. It knows nothing about your router and its config, and has no means to discover anything about that. Either it will be able to connect to something or not (and hopefully it will be whatever is runnning on internal machine and listening on that port).
anav
Mon Feb 20, 2023 2:12 am
I can port check a MT destination nat rule using gibson's site and it will show the port as existing but closed.
If I add a source address on the DST NAT rule, the port will not show at all.
Suffice to say, the only way to honestly check is with your cell phone (with wifi turned off) to see if
a. you can ping the wanip of the router
b. you can ping the server IP.
Or get a friend to connect to the server.........
PreambleDoorpost
Mon Feb 20, 2023 2:49 am
The end goal here is for uploading on peer-peer connections aka bittorrent.
I think I've got it working but my upload speeds are only hitting 100 bits to 12kb/s so very slow on a 1gig connection.
This is through a VPN, would I need to set up additional rules?
Sob
Mon Feb 20, 2023 3:52 am
@anav: There can be different results, and there's also difference between tcp and udp.
In case there wouldn't be any firewall, tcp connection that reaches target host always gets something back, either ack (when something listens on that port = it's open) or rst (when nothing listens there = it's closed). With udp it's different, because it's just individual packets, so even if something listens on that port, it doesn't mean that it will send something back. As a result, you can't clearly tell whether the port is open. When it's closed, there will be icmp message.
When there's firewall that drops packets (= nothing comes back), then for tcp it can be identified as separate filtered state. For udp it's same as before, nothing comes back, so it's either open or filtered.
Another thing to remember is that remote client can't tell what responds. If you have correct port forwarding, it's target machine. If you mess it up, it's your router. If you forget that you don't even have public address, it's ISP's router. And whichever it is, it all looks the same.
Sob
Mon Feb 20, 2023 4:04 am
Ability to upload with BT or speed of it doesn't have much to do with ability to accept incoming connections. It just makes connecting between clients easier, but it doesn't mean that it would be impossible without it.
Using VPN does need some extra config, which depends on what kind of VPN it is.
anav
@sob isnt it past your bedtime LOL...........
Users browsing this forum: Irish9 and 86 guests
