would it be possible to set up something so that I can bypass the current provider?
I have a bridge-wan where I have a modem from provider number 1 connected to port1
I also have LT1 in bridge-wan, where I had the primary provider number 2 connected, this provider has already ended
I had priority set, when provider number 1 went down, it connected through provider number 2, which I don't have, but it worked
However, I have a xiaomi gateway that is blocked by provider number 1, but it worked through provider number 2
can it be set so that instead of lte1, I would have a finevpn connection as a secondary connection, and I would only go to the provider's replacement connectivity number 1?
any instructions for setting this on mikrotik?
Thanx
