RodoggA
Getting Started with Mikrotik & Home Network Guidance
Sun Feb 12, 2023 3:11 pm
Hi Everyone,
As a renter, I'm trying to structure my home LAB so that if I move in with someone else, I can hook into the existing network with minimum changes.
Current Use Case
I'm home-sharing with the Landlord, and I'm trying to set it up where their existing network (192.168.1.0/24) is segmented from my side of things(Own Subnets & VLANS), so I can try different things without breaking the rest of the network. Only everything on my side of the hAP ax2 would be impacted.
I'm only just getting started with Mikrotik since a colleague recommended it. This is what my network looks like:
The whole idea behind it is if I move out into another place, I can hook my hAP ax2 into the existing router and be isolated from the rest of the network to break things as I do trial and error at my own will.
I'm using the Cloudflare tunnel to route to applications hosted internally to try and avoid having to do port forwarding on the landlord's router.
This is where I'm getting stuck. I'm finding an application hosted on a VM can't be reached due to a bad gateway via the Cloudflare tunnel, but I can reach it internally using its internal IP.
When discussing this with my colleagues, they mentioned that for me to reach internally hosted applications, I would either need to port forward or look at a DMZ solution. I'm hoping with CF tunnel, that I can avoid that.
This is my current configuration:
bash
[admin@MikroTik] > export compact
# feb/12/2023 20:49:24 by RouterOS 7.7
add admin-mac=18:FD:74:BB:C2:B1 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment="Uplink to home router"
set [ find default-name=ether2 ] comment="Downstream CoreSwitch"
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-BBC2B5
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-BBC2B6
/interface vlan
add comment="Data VLAN" interface=ether2 name=ether2.99 vlan-id=99
add comment="Management VLAN" interface=ether2 name=ether2.100 vlan-id=100
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool3 ranges=192.168.99.20-192.168.99.240
add name=dhcp_pool4 ranges=192.168.100.20-192.168.100.40
add address-pool=dhcp_pool3 comment="DHCP | DataVLAN.99" interface=ether2.99 lease-time=8h name=dhcp1
add address-pool=dhcp_pool4 comment="DHCP | MGMTVLAN.100" interface=ether2.100 lease-time=8h name=dhcp2 relay=192.168.100.1
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add interface=ether2.99 list=LAN
add interface=ether2.100 list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.99.1/24 interface=ether2.99 network=192.168.99.0
add address=192.168.100.1/24 interface=ether2.100 network=192.168.100.0
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.99.237 client-id=ff:9f:6e:85:24:0:2:0:0:ab:11:cc:fa:15:6:42:c5:f0:fb mac-address=00:0C:29:5A:49:8C server=dhcp1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
add address=192.168.99.0/24 gateway=192.168.99.1
add address=192.168.100.0/24 gateway=192.168.100.1
set allow-remote-requests=yes cache-size=8192KiB max-concurrent-queries=1000 max-concurrent-tcp-sessions=2000 servers=1.1.1.1 use-doh-server=\
    https://htq09quqqk.cloudflare-gateway.com/dns-query verify-doh-cert=yes
/ip dns static
add address=192.168.88.1 comment=defconf disabled=yes name=router.lan
add address=172.64.36.1 name=cloudflare-dns.com
add address=172.64.36.2 name=cloudflare-dns.com
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Australia/Perth
/tool mac-server
/tool mac-server mac-winbox
When I use torch, I can see the arp request come in but after that, nothing. Any ideas?
Happy for responses to be links to resources for my reading.
Users browsing this forum: No registered users and 63 guests
