Code: Select all
[admin@mikrotik] > export
# feb/12/2023 13:43:24 by RouterOS 7.7
# software id = TI09-7WK3
set [ find default-name=ether1 ] disable-running-check=no name=Exsi-Lan
set [ find default-name=ether2 ] disable-running-check=no name=PCIE-Lan1
set [ find default-name=ether2 ] disable-running-check=no name=PCIE-Lan2
set [ find default-name=ether3 ] disable-running-check=no name=R730xd-LAN
set [ find default-name=ether4 ] comment=DX disable-running-check=no name=WAN-DX
set [ find default-name=ether5 ] comment=LT disable-running-check=no name=WAN-LT
/interface pppoe-client
add add-default-route=yes comment=ISP-LT disabled=no interface=WAN-LT name=pppoe-out1 user=xxxxxxx
add add-default-route=yes comment=ISP-DX disabled=no interface=WAN-DX name=pppoe-out2 user=xxxzzz
/interface lte apn
add name=dhcp_pool0 ranges=223.255.255.2-223.255.255.254
add name=dhcp_pool1 ranges=223.255.255.2-223.255.255.254
add address-pool=dhcp_pool1 interface=R730xd-LAN name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=223.255.255.1/24 interface=R730xd-LAN network=223.255.255.0
add address=223.255.255.0/24 gateway=223.255.255.1
set allow-remote-requests=yes servers=223.5.5.5
add action=accept chain=input comment="22\B6\CB\BF\DA\B7\C5\D0\D0" dst-port=22 in-interface=pppoe-out1 protocol=tcp
add action=accept chain=input comment="22\B6\CB\BF\DA\B7\C5\D0\D0" dst-port=22 in-interface=pppoe-out2 protocol=tcp
add action=accept chain=input comment="8291\B6\CB\BF\DA\B7\C5\D0\D0" dst-port=8291 in-interface=pppoe-out1 protocol=tcp
add action=accept chain=input comment="8291\B6\CB\BF\DA\B7\C5\D0\D0" dst-port=8291 in-interface=pppoe-out2 protocol=tcp
add action=accept chain=input comment="100\B6\CB\BF\DA\B7\C5\D0\D0" dst-port=100 in-interface=pppoe-out1 protocol=tcp
add action=accept chain=input comment="100\B6\CB\BF\DA\B7\C5\D0\D0" dst-port=100 in-interface=pppoe-out2 protocol=tcp
add action=drop chain=input comment="drop\CD\E2\CD\F8\B7\C3\CE\CA\C2\B7\D3\C9\C6\F7" in-interface=pppoe-out1
add action=drop chain=input comment="drop\CD\E2\CD\F8\B7\C3\CE\CA\C2\B7\D3\C9\C6\F7" in-interface=pppoe-out2
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=223.255.255.0/24
add action=masquerade chain=srcnat out-interface=pppoe-out2 src-address=223.255.255.0/24
add action=dst-nat chain=dstnat dst-port=100 in-interface=pppoe-out1 protocol=tcp to-addresses=223.255.255.0/24 to-ports=100
add action=dst-nat chain=dstnat dst-port=100 in-interface=pppoe-out2 protocol=tcp to-addresses=223.255.255.0/24 to-ports=100
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system hardware
set allow-x86-64=yes
/system identity
set name=mikrotik
[code]
