shalak
Import private SSH key via CLI in RotuerOS 7.7+
Sun Feb 12, 2023 6:04 pm
I'm provisioning my good old hap ac2 that runs ROS 6 with CLI scripts. Now I'm upgrading it to Chateau, and there are several commands that stopped working for Router 7.7+.
First are the
/interface/wireless
which I understand has been deprecated in favor of
wifiwave2
package. I guess the only option is to refactor my configuration script.
However, the following also doesn't work:
/user ssh-keys private import user=admin private-key-file=flash/id_rsa_router public-key-file=flash/id_rsa_router.pub passphrase=""
There's no
public-key-file
, nor
passphrase
parameters now with
/user/ssh-key/private/import
How can I import my keys via non-interactive CLI?
pjkundert
Re: Import private SSH key via CLI in RotuerOS 7.7+
Mon Apr 03, 2023 7:53 pm
I'm running into the same thing; trying to create scripting to automate the deployment of private keys is now impossible.
Mikrotik: Please add the "passphrase=" parameters to the /user/ssh-keys/private/import command!
rextended
Mon Apr 03, 2023 10:50 pm
You run the script on Terminal, on SSH, on script, on scheduler or by importing .rsc?
But, regardless of the missing password (is asked on terminal/SSH, not on script/scheduler) the correct syntax is:
/user ssh-keys
import public-key-file=pubkey.ext user=username
private import private-key-file=prikey.ext user=username
With /system ssh-exec can be circumvented, but SSH must already be configured and working, and loopback (127.0.0.1) not blocked on firewall:
/system ssh-exec address=127.0.0.1 output-to-file=results.txt \
command="/user ssh-keys;import public-key-file=pubkey.ext user=username;private import private-key-file=prikey.ext user=username\n<PASSWORD>\n"
Just replace <PASSWORD> with correct password.
Users browsing this forum: No registered users and 25 guests
