halcy0n
Wireguard client?
Mon Feb 13, 2023 2:39 am
The documentation I've read (https://help.mikrotik.com/docs/display/ROS/WireGuard) covers setting up a wireguard server.
I couldn't decipher how I can set-up a client to route traffic from the LAN through a wireguard client interface?
Any tips or help would be great.
holvoetn
Re: Wireguard client?
Mon Feb 13, 2023 11:53 am
Actually there is no client/server in wireguard. Everything is a peer.
But let's assume there is ...
It depends on the client you are using.
If e.g. Windows, you need to install the Wireguard service and then setup the connection using private/public key as specified in app.
Can you be a bit more specific on what you're trying to do ?
halcy0n
Mon Feb 13, 2023 12:31 pm
Ahh okay that makes a bit more sense.
What I am trying to do is create a tunnel to a wireguard peer (details provided by VPN provider) and then route LAN traffic from some devices via this tunnel/interface.
Here is a simplistic diagram to visualise.
holvoetn
Mon Feb 13, 2023 12:43 pm
So you want to setup the tunnel from AX3 to public VPN ?
See viewtopic.php?t=182340
section 7.
halcy0n
Tue Feb 14, 2023 11:30 am
Perfect, thank you 🙏
Users browsing this forum: No registered users and 111 guests
