jamiesunnet
TeamsACS is the new Mikrotik TR069 ACS server
Mon Feb 13, 2023 8:06 pm
TeamsACS is an open source TR069 Auto-configuration server (ACS) specially designed for Mikrotik devices, which is designed to help administrators manage and configure Mikrotik devices remotely through the TR069 protocol
The core of the system is based on Golang technology, providing superior performance and an easy deployment experience.
TeamsACS uses Timescaledb as the primary data store, supporting time-series data and providing support for system observability
- TR069-based device management
TeamsACS implements the TR069 protocol server, supports Mikrotik as a TR069 protocol client for secure access, and supports Mikrotik TR069 private features, supports configuration reading and modification, and supports uploading Mikrotik script files for execution.
- Device Backup Management
The TR069 protocol enables Mikrotik devices to be backed up regularly and then downloaded to the TeamsACS file system for unified management, and supports backup restoration via TR069.
github: https://github.com/CA17/TeamsACS
TeamsACS Documentation Wiki: https://github.com/CA17/TeamsACS/wiki
Just yesterday, I released the first working version v1.0.1, welcome
quickstart: https://github.com/CA17/TeamsACS/wiki/quickstart
Docker Deployment: https://github.com/CA17/TeamsACS/wiki/Docker-Deployment
MattC86
Re: TeamsACS is the new Mikrotik TR069 ACS server
Tue Jun 13, 2023 9:14 am
Hi there,
I gave this a try to see how it compares to other provisioning platforms (Genie / TGEM / etc) however whether I compile, use the binary or the docker image I still cannot get past the login screen which does allow any login combination of admin / teamsacs etc
if there is a perhaps a more details step by step it would be greatly appreciated.
Thank you.
eallen
Thu Aug 03, 2023 4:41 am
I got the Docker Deploy to work and the web page comes up however, the default user and password listed in the readme does not work. I could really use some help with this.
cvanden
Sun Dec 03, 2023 2:54 am
did some digging and it looks like the install does not create any users in the database. If you login to the postgres server you can insert the default user manually using this:
INSERT INTO sys_opr (id, realname, mobile, email, username, password, level, status, remark) VALUES (1, 'administrator', '0000', 'N/A', 'admin', '3338d6e89845d18c86e40ceb5b47cff043997edda0886f259f09bdce11163d68','super', 'enabled', 'super');
once I did this i was able to login using the default admin/teamsacs
Users browsing this forum: Google [Bot], raiser and 82 guests
