martinf11
RIP alternative after upgrade to 7.x
Tue Feb 14, 2023 11:14 am
After upgrading to 7.x I realized that my RIP is not working because authentication was probably removed in 7.x. I added the routes manually, but now I am trying to choose an alternative to RIP. What is the simplest routing protocol that Mikrotik has. It should support authentication or any auth mechanism. I have 4 routers, 20 networks, nothing special. Should I use OSPF? Thank you very much.
satman1w
Re: RIP alternative after upgrade to 7.x
Tue Feb 14, 2023 2:56 pm
OSPF is the obvious choice, but RIP should work too... as far as I know
normis
Tue Feb 14, 2023 3:26 pm
RIP works in v7 just the same as in v6. If something is not working for you, post your problem in more detail, or email support with supout.rif file
Users browsing this forum: dioeyandika and 52 guests
