alexanderkirchner
Email notifications not working
Tue Feb 14, 2023 3:25 pm
Hi guys! I'm trying to set up email notifications but I can't get it to work. When hitting the test button I'm not getting any emails. I'm using The Dude version 6.49.4. I've triple checked the password, obviously. What am I missing?
nikc
Re: Email notifications not working
Tue Feb 14, 2023 3:56 pm
Not sure if SSL StartTLS is supported, have you tried on the unencrypted ports ?
massinia
Tue Feb 14, 2023 4:23 pm
Have you turned on two factor authentication for Microsoft account?
If yes you need to generate an app password, you can't use that of the account.
alexanderkirchner
Tue Feb 14, 2023 5:13 pm
No, I haven't. What ports are those? I tried 465 but that didn't work either.
No, I don't think that two factor authentication is activated. I always login normally with my email and password and nothing else.
stmx38
Long time Member
Long time Member
Wed Feb 15, 2023 12:20 am
Just did a test using Outlook account accordingly to the documentation configuration settings - POP, IMAP, and SMTP settings for Outlook.com and settings are similar to the 365 - POP, IMAP, and SMTP settings.
CHR 7.7 / Dude 7.7 - Tls Mode: yes
With 'Tls Mode: tls-only' an error appear int the ROS logs.
alexanderkirchner
Wed Feb 15, 2023 9:25 am
I tried using Gmail too, using the settings I found here: viewtopic.php?t=122952
But I'm getting a AUTH failed error in the ROS logs. I'm sure I'm using the right password.
BillyVan
Wed Feb 15, 2023 9:53 am
alexanderkirchner
Wed Feb 15, 2023 11:16 am
Hey, wow, that actually worked. Thank you!
pe1chl
Wed Feb 15, 2023 11:52 am
For now. These are being deprecated as well.
You need to follow the advisories from Microsoft around authentication. Things are being changed all the time, what works today may be deprecated next month.
Users browsing this forum: No registered users and 31 guests
