ynblpb
Cannot access to webfig from internet
Tue Feb 14, 2023 11:20 pm
Hello! Such a stupid question, i know, but I lost a lot of hours trying to solve it
I have CHR on digitalocean.
CHR used for private VPN
So, I have:
ether1 - public network
ether2 - private DO network (not configured)
l2tp-danny - server L2TP
I can not access to webfig using public network (ether1)
But can access to webfig only if I connected to VPN
Here is my configs:
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
/interface l2tp-server
add name=l2tp-danny user=danny
add name=VPN
add name=vpnclients ranges=192.168.111.2-192.168.111.200
/ppp profile
add local-address=vpnclients name=vpnclients remote-address=vpnclients \
    use-compression=yes use-encryption=yes use-ipv6=no
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=l2tp-danny list=VPN
add address=46.101.*.*/18 interface=ether1 network=46.101.*.*
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1 use-doh-server=\
    https://1.1.1.1/dns-query
add action=accept chain=input comment="accept established,related,untracked" \
add action=drop chain=input comment="drop invalid" connection-state=invalid
    "accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="Allow connections to VPN Server" \
    dst-port=1701,500,4500 in-interface=ether1 protocol=udp
add action=accept chain=input src-address=192.168.111.0/24
add action=accept chain=input dst-port=80 protocol=tcp - added this rule while testing
add action=accept chain=forward comment="Allow connections to VPN Server" \
    in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input dst-port=8888 in-interface=ether1 protocol=tcp
    in-interface=ether1 protocol=gre
add action=accept chain=input dst-port=1194 protocol=tcp
add action=accept chain=input in-interface-list=VPN
add action=accept chain=forward in-interface-list=VPN
add action=accept chain=input src-address=93.92.*.* - my home IP
add action=drop chain=input comment="drop all"
add action=accept chain=forward ipsec-policy=in,ipsec
add action=accept chain=forward ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward connection-state=\
    established,related hw-offload=yes
    "accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add gateway=46.101.*.*
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.111.0/24,93.92.*.*/32 - I've added local VPN clients and my home IP address (default port 80)
set ssh disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
What's wrong? :)
markKn
Re: Cannot access to webfig from internet
Wed Feb 22, 2023 4:55 pm
There is a setting under tools that states what interfaces the confiiguration will allow connections from--wan and lan for example. I don't know about vpns, so can't speak to that.
k6ccc
Wed Feb 22, 2023 5:08 pm
DANGER! DANGER! Will Robinson! DANGER! DANGER!!
Without some additional security, leaving Webfig accessible from the internet is just asking to get hacked. At the very least use some combination of: Port Knock, restricting access to specific known IP addresses, using non-standard ports. FAR better yet is setting up VPN access into it.
holvoetn
Wed Feb 22, 2023 5:38 pm
Don't bother allowing direct access from internet into your box.
Access through VPN sounds just about perfect to me.
That's how it is supposed to be done.
Users browsing this forum: normis, sch and 111 guests
