fakeusername2022
lack of TPROXY module in RouterOS Kernel and Docker containers
Wed Feb 15, 2023 10:03 am
Hi
I am creating a container which uses iptables and specifically focuses on utilizing TPROXY (https://www.kernel.org/doc/Documentatio ... tproxy.txt) but am not able to add any of the Iptable rules inside the docker environment (I connect to it using running shell).
I was curious about the RUN mode of dockers inside RouterOS. Are containers launched with "--privileged" and "--cap-add=NET_ADMIN" ?
Any ideas how to use Iptables and Tproxy inside a docker container on the Routeros?
Last edited by fakeusername2022 on Thu Feb 16, 2023 12:27 am, edited 1 time in total.
elbob2002
Re: Docker Container RUN mode for Mikrotik
Wed Feb 15, 2023 2:16 pm
RouterOS doesn't use Docker.
I think it uses LXC or a derivitive. Open to correction here.
Amm0
Wed Feb 15, 2023 2:43 pm
AFAIK there is no equivalent to the option "--privileged". The ability to gain root on the router is something Mikrotik guards against, so --privileged isn't likely.
Similarly, with NET_ADMIN, RouterOS doesn't allow a container direct access to system ethernet devices – traffic goes through the VETH only. NET_ADMIN would allow access to ALL interfaces, not just the VETH.
fakeusername2022
Wed Feb 15, 2023 3:22 pm
Any suggestions on how to create a docker container for Routeros which supports iptables and it's modules including tproxy?!
Routeros firewall itself does not allow something similar to tproxy, or does it?!
Amm0
Wed Feb 15, 2023 4:01 pm
I don't know much about the TOR ecosystem. But you can use VLANs on the VETH to a container. Say two VLANs on VETH:
one VLAN can be the IN traffic and one VLAN can be OUT traffic.
But the TOR software in the conatain have to be setup to use that kinda scheme. Dunno know if possible.
fakeusername2022
Wed Feb 15, 2023 4:47 pm
Amm0
Wed Feb 15, 2023 5:20 pm
LOL. Wrong container. Same answer. MT don't allow root things in containers. So no NET_ADMIN or --privilege
Mikrotik has suggest some TAP/TUN support in future. It's a tricky because they are trying to avoiding a compromised container from hacking the router. With those options, that be trivial.
Amm0
Wed Feb 15, 2023 5:24 pm
TOR?!
I blame the @fakeusername2022 username for my mistake ;)
fakeusername2022
Wed Feb 15, 2023 9:46 pm
One step forward...
I listed all exposed Kernel modules from RouterOS to a running container (as you know containers do not have any Linux Kernel and depend JUST on the host kernel. Therefore, just the loaded Kernel Modules of the main RouterOS kernel is available to them).
So here is the output. Others might find this interesting:
 lsmod
Module                  Size  Used by
chacha20poly1305       16384  0
esp6                   20480  0
ah6                    16384  0
esp4                   20480  2
ah4                    16384  0
camellia_generic       32768  0
twofish_generic        20480  0
twofish_common         24576  1 twofish_generic
sch_rate               16384  51
sch_pcq                20480  4
ip6_tables             24576  0
imq                    16384  0
cls_linear             20480  8 imq
cls_fw                 20480  1 imq
sch_htb                28672  4
wireguard              65536  0
ip6_udp_tunnel         16384  1 wireguard
udp_tunnel             20480  1 wireguard
curve25519_x86_64      40960  1 wireguard
libcurve25519_generic    49152  2 curve25519_x86_64,wireguard
libchacha20poly1305    16384  1 wireguard
poly1305_x86_64        28672  1 libchacha20poly1305
chacha_x86_64          28672  1 libchacha20poly1305
libchacha              16384  1 chacha_x86_64
libblake2s             16384  1 wireguard
blake2s_x86_64         20480  1 libblake2s
libblake2s_generic     20480  1 blake2s_x86_64
veth                   20480  0
iptable_raw            16384  1
ipt_SAME               16384  0
xt_NETMAP              16384  0
xt_REDIRECT            16384  0
xt_MASQUERADE          16384  3
xt_nat                 16384  9
iptable_nat            16384  1
iptable_mangle         16384  2
ipt_TARPIT             16384  0
ipt_REJECT             16384  0
nf_reject_ipv4         16384  1 ipt_REJECT
iptable_filter         16384  1
nf_defrag_ipv4         16384  0
ipt_psd                16384  0
ip_tables              24576  4 iptable_filter,iptable_raw,iptable_nat,iptable_mangle
ipt_snif               16384  0
snif                   16384  1 ipt_snif
ipt_ulog               16384  2
xt_tls                 16384  2
xt_layer7              20480  0
xt_HL                  16384  0
xt_DSCP                16384  0
xt_TCPMSS              16384  1
xt_CT                  16384  0
xt_policy              16384  0
xt_addrtype            16384  6
xt_hl                  16384  0
xt_realm               16384  0
xt_physdev             16384  0
xt_length              16384  0
xt_connbytes           16384  0
xt_helper              16384  0
xt_tcpmss              16384  0
xt_dscp                16384  0
xt_hashlimit           20480  0
xt_statistic           16384  0
xt_string              16384  2
xt_connmark            16384  15
xt_conntrack           16384  0
xt_multiport           16384  10
xt_mark                16384  14
xt_mac                 16384  0
xt_tcpudp              16384  5
ts_kmp                 16384  2
vmxnet3                45056  0
xt_misc                20480  42
x_tables               24576  41 xt_dscp,ipt_psd,xt_conntrack,xt_statistic,iptable_filter,ipt_SAME,xt_multiport,xt_length,xt_string,xt_tcpudp,xt_DSCP,xt_tcpmss,xt_hashlimit,xt_addrtype,xt_physdev,xt_nat,ipt_snif,xt_layer7,xt_helper,xt_NETMAP,xt_policy,ip6_tables,xt_HL,xt_mac,xt_tls,ipt_TARPIT,ipt_ulog,ipt_REJECT,xt_connmark,xt_CT,xt_realm,iptable_raw,ip_tables,xt_hl,xt_misc,xt_MASQUERADE,iptable_mangle,xt_TCPMSS,xt_REDIRECT,xt_mark,xt_connbytes
nf_conntrack_ipv4      16384  0
des3_ede_x86_64        40960  0
nf_nat                 28672  6 ipt_SAME,xt_nat,xt_NETMAP,iptable_nat,xt_MASQUERADE,xt_REDIRECT
des_generic            16384  0
nf_conntrack_netlink    28672  0
libdes                 24576  2 des_generic,des3_ede_x86_64
nfnetlink              16384  1 nf_conntrack_netlink
sha512_ssse3           45056  0
sstp                   45056  1
sha256_ssse3           32768  1
blowfish_generic       16384  0
blowfish_common        20480  1 blowfish_generic
echainiv               16384  2
ovpn                   24576  1
sha1_ssse3             28672  28
l2tp                   69632  1
ppp_mppe               16384  0
sha512_generic         16384  1 sha512_ssse3
arc4                   16384  0
af_key                 28672  4
bridge2_netfilter      20480  0
libarc4                16384  1 arc4
sha1_generic           16384  1 sha1_ssse3
wlan                  294912  3
xfrm_user              28672  2
vrf                    20480  0
ppp_deflate            16384  0
aesni_intel           323584  56
zlib_inflate           20480  1 ppp_deflate
capsmanglue            12288  1 wlan
xfrm_algo              16384  6 esp6,af_key,esp4,ah6,ah4,xfrm_user
zlib_deflate           24576  1 ppp_deflate
ppp_generic            28672  132 l2tp,ppp_mppe,ppp_deflate,sstp
btest                  16384  0
glue_helper            16384  1 aesni_intel
lm87                   20480  0
hwmon_vid              16384  1 lm87
ledgroup               20480  0
tun                    32768  0
slhc                   16384  0
crypto_simd            16384  1 aesni_intel
cryptd                 16384  29 crypto_simd
ulog                   16384  2 ipt_ulog
bridge2               118784  1 bridge2_netfilter
switch                 45056  1 bridge2
phy_helper             45056  1 switch
packet_hook           131072  18 bridge2,l2tp,switch,xt_layer7,wlan,vmxnet3,xt_misc
tunnel6                16384  1 packet_hook
nf_conntrack           73728  14 xt_conntrack,nf_conntrack_ipv4,nf_nat,packet_hook,xt_nat,xt_helper,xt_NETMAP,nf_conntrack_netlink,xt_connmark,xt_CT,xt_misc,xt_MASQUERADE,xt_REDIRECT,xt_connbytes
jiffies                16384  61
softdog                16384  2
wdat_wdt               16384  0
ipv6                  299008  166 bridge2,l2tp,vrf,esp6,packet_hook,ovpn,bridge2_netfilter,ah6,wireguard
nf_defrag_ipv6         16384  2 nf_conntrack,ipv6
logring                40960  202
unix                   32768  334
ALSO as per Linux Kernel documentation:
Iptables and nf_tables extensions
To use tproxy you’ll need to have the following modules compiled for iptables:
NETFILTER_XT_MATCH_SOCKET
NETFILTER_XT_TARGET_TPROXY
Or the floowing modules for nf_tables:
NFT_SOCKET
NFT_TPROXY
So I think it is impossible to have a container on RouterOS which utilizes the "TPROXY" target for its purposes. Maybe Mikrotik Dev team will consider loading these modules into the RouterOS Kernel to provide the flexibility and functionality required by some containers.
P.S.
These are the above mentioned modules which are found on my VM running Ubuntu LTS:
root@ubuntu-lts-hyperv:~# locate NETFILTER_XT_MATCH_SOCKET NETFILTER_XT_TARGET_TPROXY NFT_SOCKET NFT_TPROXY
/usr/src/linux-headers-5.15.0-60-generic/include/config/NETFILTER_XT_MATCH_SOCKET
/usr/src/linux-headers-5.15.0-60-generic/include/config/NETFILTER_XT_TARGET_TPROXY
/usr/src/linux-headers-5.15.0-60-generic/include/config/NFT_SOCKET
/usr/src/linux-headers-5.15.0-60-generic/include/config/NFT_TPROXY
Amm0
Thu Feb 16, 2023 12:39 am
Great info. That actually make me feel better – you shouldn't have been able to ;).
Totally get the need – it's a router & now "software extendable" with containers SO yes that custom software (e.g. containers) might want to access the raw interfaces directly.
I think they're taking it slow, to let the current features settle in first. /container is perfectly usable for "services" (e.g. one veth interface is fine for that). But for SDN/"packet processing things" – this where you want a lot more options to intact with network interfaces themselves. Whether it be a straight mapping to the Docker options --privilege, NET_ADMIN stuff, or something different, dunno. But MT had to have thought about the future SDN-like use cases for their containers.
Users browsing this forum: No registered users and 2 guests
