Taleb
Use a master router as a database of hotspot users?
Thu Feb 16, 2023 3:21 pm
Hello brothers
Is it possible to use a master router as hotspot database users so that all network clients can connect through the various routers?
I know this idea can be applied with UserManager by makes the UserManager database in the main router.
But can the same idea be applied by Hotspot?!
I don't want to use UserManager.
bpwl
Re: Use a master router as a database of hotspot users?
Thu Feb 16, 2023 5:33 pm
Specifically Usermanager 4 (ROS6) and 5 (ROS7) ? Or just any central authentication like RADIUS aurhentication?
(FreeRADIUS, NAS based, Windows AD, LDAP, SSO, other vendor router based (e.g. With Draytek the router local user base is used for hotspot and available as RADIUS authentication server))
"Use RADIUS" is so obvious here. Could even handle your AP's AAA from RADIUS, including from Usermanager 5.
Taleb
Thu Feb 16, 2023 6:12 pm
Thank you very much for your reply.
What about the idea that I presented?!
I mean to use the hotspot database on a different router?!
Is it technically feasible or not?!
bpwl
Thu Feb 16, 2023 6:43 pm
Or only the Hotspot on the main router, as this seems to be the only path to internet
Something like this (the ethernet case is a simple setup with MT) : https://www.mywifiservice.com/en/instal ... Fi_Network
binooetomo
Sat Mar 11, 2023 8:25 am
I'm afraid Radius is the only way you can go.
We can think that UserManager have 2 main part:
1. User database and Database Management UI.
2. Radius Server, the one that serve other (including local) host about remote authentication.
-bino-
Users browsing this forum: Fi011, intania, Techsystem and 219 guests
