JustAnAccount
Save backup infinite loading
Fri Feb 17, 2023 11:18 am
I have around 30 CRS328-24P-4S+RM running Swos and would like get a backup fill from all of them. Which works as expected with the exception of 5 devices. When pressing the save Backup button a new empty windows open and loads indefinitely. Rarely the popup to save appears on those 5 devices after a long load time but the actual saving fails afterwards.
I remember this issue happening 2 years ago on the same switches but I had no time then to find the solution. Now that I have more time and the devices have had a few updates I gave it one more try with the same results.
All the switches are on the latest swos version (2.13).
I tried with multiple browsers (Firefox; chrome, etc...), devices etc
Anyone has a workaround for this bug?
k6ccc
Re: Save backup infinite loading
Sat Feb 18, 2023 1:26 am
Can you post a screen capture of what you are seeing?
Users browsing this forum: No registered users and 6 guests
