soran1
import adguard dns container image problem
Sat Feb 18, 2023 7:41 pm
hello everyone,i have problem when i want to install or pull the docker image the problem is (error response getting manifests: 404)
when using( https://registry-1.docker.io) its just not there any more so ,what to use for the registry URL
Zakazulu
Re: import adguard dns container image problem
Sun Feb 19, 2023 3:51 pm
i'm trying to set adguard on my rb5009 and i am getting the same error. On my AX3 i did the same thing and it just works?
soran1
Re: import adguard dns container image problem  Topic is solved
Mon Feb 20, 2023 1:41 am
i just find the sloution i had to download the adgaurd image file with windows docker and i save it as tar file then upload it to my 4011rb and its worked
tricyclevent
Mon Feb 20, 2023 3:19 pm
I have the same problem. No more Adguard container possible for RB4011.
"error response getting manifests: 404"
"was unable to import, container 150b8c16-e633-4ade-9f88-61dc463961c5"
Can you upload the image? I have no idea how docker for windows works..
Z0ltan
Mon Feb 20, 2023 10:19 pm
It seems docker now requires authentication, however that’s only supported in 7.8.
tricyclevent
Tue Feb 21, 2023 12:03 pm
How to use the authentication?
In terminal i set up username & password. But how to connect?
I changed the url to: https://registry-1.docker.io/v2/
Tests all possibilities (urls, different dockers), but no success.
I m on 7.8rc2 (testing).
Z0ltan
Tue Feb 21, 2023 8:50 pm
Can you try with https://index.docker.io/v2/ ? And use your working docker credentials.
tricyclevent
Wed Feb 22, 2023 8:20 pm
Adguard/Adguardhome:
with Url: https://index.docker.io/v2/
i get: "error response getting manifests: 401"
i get: "error response getting manifests: 404"
Pihole/Pihole:
Succes, download start, pihole starts with success
whats the difference on Adguard?
And are my credentials activ? How to check?
tricyclevent
Wed Feb 22, 2023 9:48 pm
Z0ltan
Thu Feb 23, 2023 3:10 pm
Interesting, thanks for those links. Upon first investigation I noticed Mikrotik was using a different registry than my docker installation on Synology and using that repo required authentication, that's why I thought lack of authentication is the crux of the problem; I never thought the manifest format was changed. I guess we're left with the manual export of the tar file from a system that's actually capable of retrieving the container.
antonsb
Fri Feb 24, 2023 8:58 am
thanks for reporting this, we will check how to fix this in upcoming versions
Amm0
Fri Feb 24, 2023 12:18 pm
Hmm. I recently trying to use ghcr,io as the "Container Registry" to pull /containers (e.g. /container/config/registry-url=https://ghcr.io) with GitHub's CI for my own images.
Ran into this problem when building an image through GitHub's Actions however...
But I bet it be similar with the adguard image too.
GitHub's CI builder, by default uses "attestations" (metadata) and adds theses to the docker buildx:
docker buildx build --sbom=true --provenance=true ...
However, those options cause "fake platform" of "unknown/unknown" in the package (that must store them I guess) for download in the registry (e.g. GitHub's DockerHub).
And RouterOS gets the same 404 and "error" status as reported for adguard.
Removing those explicitly disabling in the GitHub workflow.yaml "build-and-push-docker-images" action fixed my custom package:
   - name: Build and push
      uses: docker/build-push-action@v4
      with:
        context: .
        push: true
        sbom: false
        provenance: false
        platforms: linux/arm64,linux/arm/v7
But that's not so easily done for other people's packages. But default are "true" for both "sbom" and "provenance", and that breaks RouterOS's /container pull it seems... so that effect most public images built on GitHub I'd imagine.
This never would happen when using "docker save" locally, since the tar file doesn't support Docker's attestation AFAIK.
blackhandnz
Tue Feb 28, 2023 9:31 pm
Anyone get this to work in v7.8, I still get the same issue (I assume its not fixed yet?)
Zakazulu
Tue Feb 28, 2023 10:10 pm
I got it working using a build earlier than latest. Try; adguard/adguardhome:v0.108.0-b.25
blackhandnz
Tue Feb 28, 2023 10:40 pm
Thanks that worked :)
Rhoos
Wed Mar 01, 2023 4:21 pm
Thanks, it worked for me!
blackhandnz
Wed Mar 15, 2023 9:22 pm
While the import issue is getting resolved, to update to the latest version of the container you can do this.
From your computer :
1.) docker pull adguard/adguardhome:latest@sha256:aa84b1ff0b5710052bdb8e63b4528dc9b634780019a125d3d4de320868b6cbf2
(where the digest corresponds to your Mikrotik's architecture e.g. ARM64)
2.) docker save adguard/adguardhome > adguardhome.tar
3.) Upload to your RouterOS Device and use the uploaded file to create the container
antoxic
Mon Mar 20, 2023 11:41 am
Did somebody managed to run the latest version without downloading the file to pc first?
Amm0
Mon Mar 20, 2023 12:06 pm
There is a bug in RouterOS that prevent a pull'ed image built using a newer metadata format from loading. So until Mikrotik fixes the bug, no. It's not just adguard affected by this bug, so imagine a fix will come in the next release.
The tar file don't contain any metadata so it avoid the bug, but you can only get those using the desktop clients.
antoxic
Mon Mar 20, 2023 12:31 pm
Thanks! Well, I hope that a new release is coming soon, at least as a beta!
antoxic
Mon Mar 20, 2023 12:50 pm
Thanks. Manual download and run worked for me as well!
antonsb
Tue Mar 21, 2023 9:20 am
Fix is included in upcoming beta
Z0ltan
Sun Mar 26, 2023 11:35 am
Anyone confirmed if it’s working?
*) container - improved "container pull" to support OCI manifest format;
tricyclevent
Sun Mar 26, 2023 8:31 pm
7.9beta4
Adguard:Adguard
Z0ltan
Mon Mar 27, 2023 3:26 pm
It's actually adguard:adguardhome can you please try with that as well?
tricyclevent
Mon Mar 27, 2023 6:56 pm
adguard:adguardhome
importing remote image: adguard, tag: adguardhome
was unable to import, container bdd79662-4b0f-46ca-9deb-24d5890d6891
adguard/adguardhome
importing remote image: adguard/adguardhome, tag: latest
was unable to import, container c3a3d65f-612f-421b-83df-8b30dc724ad3
no 401 message.
optio
Long time Member
Long time Member
Mon Mar 27, 2023 8:03 pm
adguard:adguardhome
There is no adguardhome tag for that image, see: https://hub.docker.com/r/adguard/adguardhome/tags
Syntax is: <repo_image_path>[:<tag>], if tag is not specified it uses latest if exists
adguard/adguardhome
no 401 message.
Could be related to ROS docker image compatibility (OCI manifest format), try this solution: viewtopic.php?t=193727#p985424
Z0ltan
Mon Mar 27, 2023 10:37 pm
Sorry for the wrong syntax, it should be adguard/adguardhome:latest
No 401 seems promising but looks like still not working, thanks for checking, maybe the team will fix it by 7.9 final.
Z0ltan
Mon Apr 03, 2023 3:30 pm
Can you check if it works with 7.9rc1?
jodansi90
Tue Apr 04, 2023 6:46 am
It doesn't work!
Z0ltan
Tue Apr 04, 2023 4:42 pm
Interesting, I spun up 7.9rc1 as a virtual machine and found this in the logs:
13:39:58 container,info,debug importing remote image: adguard/adguardhome, tag: latest
13:39:58 system,info item added by admin
13:40:00 container,info,debug was unable to import, container 69aeeb3b-32d0-4012-8943-32344d748243
13:40:11 container,info,debug removing files, container 69aeeb3b-32d0-4012-8943-32344d748243
13:40:11 system,info item removed by admin
13:40:42 container,info,debug importing remote image: adguard/adguardhome, tag: latest
13:40:42 system,info item added by admin
13:40:44 container,info,debug was unable to import, container d114a626-8a0f-4e26-a9f1-3d296b2bcc48
It seems it can download the image but cannot import it.
jodansi90
Wed Apr 05, 2023 5:38 pm
It still doesn't work in Release 7.9rc1, help!
Josephny
Tue Apr 11, 2023 6:03 pm
Has this been fixed?
In the meantime, can anyone explain how I can download the Adguard container file on my Windows PC for moving to the RB5009?
antonsb
Wed Apr 12, 2023 3:56 pm
Hello, fix hopefully will come with next beta release.
serkamil
Thu Apr 13, 2023 8:55 pm
Dear antonsb,
do you know when it could be (next beta release?)?
BR
Kamil
antonsb
Fri Apr 14, 2023 10:49 am
beta will be released immediately after stable release. Probably next week.
vuk
Tue Apr 18, 2023 3:04 pm
you mean 7.10 beta?
antonsb
Wed Apr 19, 2023 12:56 pm
Yes fixes will come with 7.10 branch - otherwise it will slow down existing 7.9 development.
uhmhello1807
Mon May 01, 2023 1:17 pm
Thanks, this worked for me :D
MTL7
Thu May 04, 2023 5:34 pm
Where is 7.10 the branch? Can you post a note about this problem in the 7.9 rls note etc?
It takes time to figure out and rollback etc...
jodansi90
Thu May 11, 2023 11:07 pm
It worked perfectly for me in version 7.10beta5 Testing thanks
nacer
Sat May 27, 2023 11:47 pm
I have hAP ac3 on 7.10rc1
I couldn't get both methods to work.
pull method.
not ok registry auth response: 401
was unable to import, container 60913b7a-d045-477f-b917-85506f5d6dbf
image method.
importing tar archived image: adguard.tar
error: could not find image manifest in archive
arshad
Fri Jun 02, 2023 9:33 pm
I've just installed Version:
v0.106.3
and worked just fine
Telos
Tue Jun 13, 2023 6:55 pm
I just downloaded ROS ver.7.10rc5 and my adguardhome is up and running! It seems like they've fixed the metadata issue.
elico
Wed Jun 21, 2023 7:56 pm
Seems to work fine on RouterOS v7.10.
https://gist.github.com/elico/176d1c0a8 ... 1a20bd7b62
/interface/veth/add address=172.21.0.201/24 gateway=172.21.0.254 name=veth201
/interface/bridge/port/add bridge=dockers interface=veth201
/container/envs/add name=adguard_envs key=TZ value="Asia/Jerusalem"
/container/config/set registry-url=https://registry-1.docker.io tmpdir=usb1-part1/pull
/container/mounts/add dst=/opt/adguardhome/conf name=adguardhome_conf src=usb1-part1/adguardhome/conf
/container/mounts/add dst=/opt/adguardhome/work name=adguardhome_work src=usb1-part1/adguardhome/work
/container/add remote-image=adguard/adguardhome:latest interface=veth201 logging=yes mounts=adguardhome_conf,adguardhome_work root-dir=usb1-part1/adguardhome/root envlist=adguard_envs start-on-boot=yes
antoxic
Mon Jul 03, 2023 11:56 pm
I can confirm that it's working!
alushchykau
Thu Jul 27, 2023 1:14 pm
I've got a problem. Container pulled successfully, started also successfully - logs.
IP address 172.17.0.2 attached to container, I can ping it from my laptop and Mikrotik, but I can't access Adguard interface (tried ports 3000, 80, 443).
jvanhambelgium
Forum Veteran
Forum Veteran
Thu Jul 27, 2023 7:25 pm
Strange,
Works fine here.
The difference is during boot it clearly prints the veth-IP:3000 reference to login, and in your case it does not...
And I confirm the GUI works fine on my test-segment 192.168.3.4:3000
...and after first install the GUI is available on the standard HTTP-port 80.
I'm running 7.10 on RB5009
EDIT : 1 major bug or anomaly here ... it seems it works in terms of DNS-resolution, but I'm getting nothing in the statistics-screens or the query-logs remains empty!
alushchykau
Fri Jul 28, 2023 8:59 am
I've fixed it with changing VETH with IP address for container form internal network and then go back to dedicated VETH for Dockers (separate Bridge), so initial configuration was done and it's able to boot... I've got another question, after Mikrotik reboot I can see that all VETH interface IPs became 0.0.0.0/0 in WinBox, but configuration is ok, because Containers got correct IPs, can someone suggest what to check?
jvanhambelgium
Forum Veteran
Forum Veteran
Fri Jul 28, 2023 9:11 am
Yep, seems to be a Winbox bug.
On a RB3011 lab box, running the latest beta 7.11 BETA6 this "issue" is present.
Winbox entries all give 0.0.0.0/0 but on console all is OK.
Feel free to log a ticket on this with MT.
/interface/veth> print
Flags: X - disabled; R - running
0 R name="veth1" address=172.17.0.2/16 gateway=172.17.0.1 gateway6=""
1 R name="veth2" address=172.17.0.3/16 gateway=172.17.0.1 gateway6=""
2 R name="veth3" address=172.17.0.4/16 gateway=172.17.0.1 gateway6=""
3 R name="veth4" address=172.17.0.5/16 gateway=172.17.0.1 gateway6=""
alushchykau
Fri Jul 28, 2023 10:01 am
I've got the same version on my Chateau and CLI shows correct IPs, just checked it... so U are right - Winbox bug
jvanhambelgium
Forum Veteran
Forum Veteran
Fri Jul 28, 2023 10:44 am
I'm still puzzled why "Adguard" is not showing any statistics *but* it seems to be working.
My test-PC has hardcoded 1 single DNS pointing to the Adguard, dns-resolving works (I see exchange in a tcp-dump) but nothing in the logs or statistics-dashboard.
Strange .. don't think its a permission problem with the mounts, but need to check further.
EDIT : FIXED, some intercepting rules still active delivering to another resolver...
alushchykau
Fri Jul 28, 2023 12:17 pm
Is there any way to get real client IP addresses in Adguard stat? The easiest thing is to use LAN IP address instead of IP from docker subnet...
antoxic
Fri Jul 28, 2023 12:26 pm
I think if you disable NAT on docker bridge, it will solve your problem.
alushchykau
Fri Jul 28, 2023 12:44 pm
But in this case how it's better configure access from Container to the Internet?
antoxic
Fri Jul 28, 2023 1:09 pm
You should apply NAT to your container in the same way as you do for the rest of your network, on the outgoing WAN interface. So you should have a rule that is only natting when a device from your internal network tries to access the internet through your WAN interface.
alushchykau
Fri Jul 28, 2023 1:57 pm
My current NAT settings:
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
1 X chain=dstnat action=redirect protocol=tcp dst-port=53 log=no log-prefix=""
2 X chain=dstnat action=redirect protocol=udp dst-port=53 log=no log-prefix=""
3 ;;; masq. vpn traffic
chain=srcnat action=masquerade src-address=192.168.48.0/24 log=no log-prefix=""
4 chain=srcnat action=masquerade src-address=172.17.0.0/24 log=no log-prefix=""
antoxic
Fri Jul 28, 2023 2:51 pm
Try disabling the last rule. Everything should work.
alushchykau
Fri Jul 28, 2023 4:29 pm
If I will disable it Container will loose connection to the Internet, by the way I've tried - the same - only docker's bridge IP is showing in stat
antoxic
Fri Jul 28, 2023 4:33 pm
Looks like your docker container does not have a default gateway
Amm0
Fri Jul 28, 2023 5:29 pm
e.g. does the VETH for the container have the bridge IP as the gateway?
alushchykau
Sat Jul 29, 2023 12:55 pm
Yes, VETH interface used for Adguard Container has IP address and Gateway (Bridge IP address)
Users browsing this forum: No registered users and 3 guests
