davidpavelka
R11e-4G registration speed
Sat Feb 18, 2023 9:47 pm
Hi, I have Mikrotik wAP LTE Kit with R11e-4G (revision R11e-4G_V005) inside. I have specific usage where I need to register to operator as soon as possible. The problem is, that after reset of lte interface, resetting is taking about 40 seconds (from reset to actual internet connection estabilished).
Is there a way to make it faster? Or are there any other lte modules, that are faster?
Thank you.
Best regards,
David
krafg
Re: R11e-4G registration speed
Tue Feb 21, 2023 1:43 pm
All mikrotik interfaces are slow to get registered on tower. If you need permanently get connection I recommend use 2 LTE interfaces, the second as failover. It works for me with LtAP + both Mikrotik LTE interfaces. You can check this for more information.
Regards.
Users browsing this forum: Bing [Bot], maisondasilva and 57 guests
