Im configuring MikroTik hAP ac2 to work as a second router in my home network.
The goal is to connect MT with a device or two via ethernet and potentially some via WiFi
MT o[/img]dem (hardware from my ISP), ether2 is the connection to my laptop.
the setup is default - screenshoot attached
MT is struggling with the DHCP client which is stucked with status "searching.." and cant get the IP address from the modem.
The DHCP server on the modem works fine.
I've also tried some quick setups with "Home AP Dual" or "PTP Bridge AP" but the problem still ramains.
I saw few posts on the forum describing similar issue but non of them solved my problem.
Is there a guide that might give some light on what I am missing? Or maybe someone faced a similar problem and know the solution ?
Thanks in advance,
Qemothy
