Without having a look at your config and a picture of the complete network topology this device is being used in, hard to tell.
Drawing can be made on paper. Usually good enough. Make sure to indicate all different subnets.
Terminal:
/export file=anynameyouwish
Export and post between [code] quotes, mask out serial number and public WAN IP.
Hi, sharing my exported file:
# feb/20/2023 17:55:58 by RouterOS 6.49.7
# software id = PJYJ-I6T6
# model = RBD52G-5HacD2HnD
# serial number = HDJ08H484BM
add admin-mac=48:A9:8A:1A:C2:E0 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC \
country=ukraine disabled=no distance=indoors frequency=2452 installation=\
indoor mode=ap-bridge ssid=MC1 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-eeeC country=ukraine disabled=no distance=indoors frequency=\
5825 guard-interval=long installation=outdoor mode=ap-bridge ssid=MC1_5G \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=*** \
wpa2-pre-shared-key=***
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid disabled=yes
connection-state=new disabled=yes in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
/tool mac-server
/tool mac-server mac-winbox
