Not from a screenshot, it can hide some things. But based on your description in first post it should be ok. To be sure, try to run this in Terminal:
and then post content of created myconfig.rsc here in code tags.
by RouterOS 7.7
# model = RBD52G-5HacD2HnD-TC
# serial number = XXXXXXXXXXX
add admin-mac=XXXXXXXXXXXXXX auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=XXXX wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=XXXX wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=XXXXXK
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment=forum out-interface=bridge
add action=dst-nat chain=dstnat comment="Open port 7777 for CT101" \
dst-address=91.92.2.111 dst-port=7777 in-interface-list=WAN protocol=\
udp to-addresses=192.168.88.101 to-ports=7777 #192.168.88.101 correct for Virtual Machine
/ip hotspot service-port
set ftp disabled=yes
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=2001:XXX::/32 comment="defconf: documentation" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=MY IPv6::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=XXXX/XXXXX
/tool mac-server
/tool mac-server mac-winbox
