lurch
using find in expect script
Tue Feb 21, 2023 11:20 am
Via the cli i use the follwoing command
interface bridge port set [find where bridge=bridge and interface=ether5] pvid=123
however i'm having a problem executing it via a script form a remote machine.
send "interface bridge port set [find where bridge=bridge and interface=ether5] pvid=123";
returns
Password: invalid command name "find"
    while executing
"find where bridge=bridge and interface=ether5"
    invoked from within
"send "interface bridge port set [find where bridge=bridge and interface=ether5] pvid=123""
rextended
Re: using find in expect script
Tue Feb 21, 2023 11:54 am
How is executed?
The correct syntax is:
/interface bridge port set [find where bridge=bridge and interface=ether5] pvid=123
Starting with the "/", not needed on "find", is implicit "/interface bridge port"
If you do some commands before, probably is not on root "/" the current "working directory"
Users browsing this forum: No registered users and 33 guests
