mainframecn
RB4011iGS+RM
Tue Feb 21, 2023 9:43 pm
I recently became an owner of the RB4011iGS+RM, did a basic setup as a router. After a while I noticed ports 7-10 not communicating with the rest of the network i.e obtaining an ip address. I think it has something to do with the device having 2 internal switches (RTL8367). Since I have no experience with this configuration I was hoping if someone can point me in the right direction.
k6ccc
Re: RB4011iGS+RM
Wed Feb 22, 2023 7:02 pm
Likely not the issue. Please post your configuration - else we're guessing.
To export and paste your configuration (and I'm assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) "/export hide-sensitive file=any-filename-you-wish". Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
Moba
Re: RB4011iGS+RM
Thu Feb 23, 2023 1:58 am
Reset the device with the latest long term firmware/software. By default, both switches are linked with a bridge and communicate without problem. Unless a switch chip died...
Users browsing this forum: AndreKR, JRnet, mkx, PLJ020, Tony93 and 130 guests
