bornpilot
ltap mini not consistently connecting to lte LTE SIMCOM 7600G
Wed Feb 22, 2023 4:16 pm
My ltap mini is not concisely connecting to the lte network. I am getting the following command as the last command before the modem I think is trying again.
lte1: sent AT+COPS=0,0,,
I have attached two files one of the routerboard config and the other of the lte logs. The last attempt I made I started the router with the sim set to an empty slot then after the system booted I switched it over to the slot with the sim. you can see this in the logs I am not sure why it's not consistently connecting. When it does connect it's say one out 20 boots.
bornpilot
Re: ltap mini not consistently connecting to lte LTE SIMCOM 7600G  [SOLVED]
Tue Feb 28, 2023 4:36 pm
I solved the problem, I just needed to disable the non lte options under "network mode:"
Users browsing this forum: mkx and 76 guests
