I'm a complete newbie to networking and would greatly appreciate any support as my Mikrotik isn't getting Internet from my ISP's router for some reason that I can't work out.
My Mikrotik then connects to two other APs (unifi) and my hikvision security cameras. Everything seems to be fine on the LAN and I can see the cameras etc but nothing has access to the internet and even when I connect my laptop (through Wifi and wired) to the Mikrotik it doesn't get Internet.
Below is the output information that I get from the Mikrotik router. Does anyone spot an error in the settings? Thank you so much in advance for any help!
Code: Select all
# jan/02/1970 01:15:04 by RouterOS 6.40.4
# software id = QZPM-TQ8F
# model = RouterBOARD 952Ui-5ac2nD
# serial number = 924C08A58F04
add admin-mac=CC:2D:E0:DA:24:62 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-DA2467 wireless-protocol=\
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-DA2466 \
wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
