mdadigital
Getting this error: DNS_PROBE_FINISHED_NXDOMAIN  [SOLVED]
Fri Feb 24, 2023 1:34 pm
Hi guys. I have a new installed RB4011. Everything works. But I get a DNS_PROBE_FINISHED_NXDOMAIN for one specific website. I use the gateway as DNS on my computer. If I use 8.8.8.8 on my computer it works. But when I revert to gateway it does not work anymore.
Any ideas?
baragoon
Re: Getting this error: DNS_PROBE_FINISHED_NXDOMAIN
Fri Feb 24, 2023 2:27 pm
no ideas without your config
mdadigital
Sat Feb 25, 2023 4:54 pm
Sorry this might have been a ISP DNS problem that
coincided with me switching out routers. After a ipconfig /flushdns it seems to work.
rickberon
Mon May 22, 2023 8:02 am
First, check your internet connection to ensure it is stable. Then, clear your browser cache and restart the browser. If the issue persists, flush the DNS cache by using the appropriate command in the command prompt or terminal. Changing your DNS servers to providers like Google DNS or OpenDNS may also help. Additionally, disable any VPN or proxy services you're using and restart your router. If none of these steps work, it may be necessary to contact the website administrator or your internet service provider for further assistance.
Users browsing this forum: Benzebub, llamajaja and 90 guests
