Hi! After many years of using Mikrotik devices finally I need to implement VLANs, and with no luck. I read a lot of materials but because my network is not as simple as in the examples, and because my different devices need different VLANs implementations (some through bridges, some through switches), I'm stuck.
Here is a diagram of what I want to achieve.
So, I need two VLANs. VLAN1 - is a main home network (also a management network) and VLAN2 - is a guest network with less access.
DHCP, DNS, NAT, VPNs, common firewall rules, and all other main network services are on the R1 router, it's my central router. R2 - it's dumb AP. R3 - it's a dumb switch.
Because I need DHCP on R1, I can't configure it like a dumb switch with VLANs through a switch chip as in most of the examples. I tried to make two bridges (CRS112 can do hw-offload on many bridges) with VLANs in them but with no luck. I tried to make one bridge with two VLANs on it, but also with no luck. I tried to make VLANs on a switch chip, again with no luck.
Taking into account the weak CPU on R1, I need to use hw-offload whenever I can.
So I'll be very pleased if anybody helps me. I do not need help with DNS, DHCP, and other services, all I need is to figure out how to make VLANs on R1 and R2 taking into account device models. Cause as I understand CRS112 - is a special guy in the case of VLANs.
