tarana
How to eanble ip routing on a given interface?
Fri Feb 24, 2023 6:53 pm
On a CRS-354 running ROS v7.7, how can one turn on ip routing on a specific interface, for instance ether12?
It appears to me even after configuring ip address on an interface, the STP is still sending out BPDU on that interface configured as layer 3 interface. So, what is the proper way to enable ip routing on an interface on Mikrotik CRS-354 device.
Thank you,
Lawrence
k6ccc
Re: How to eanble ip routing on a given interface?
Fri Feb 24, 2023 7:02 pm
Actually it will route unless you do something to prevent it. Please post your config so we can see what you have done.
To export and paste your configuration (and I'm assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) "/export hide-sensitive file=any-filename-you-wish". Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
Users browsing this forum: jaclaz, lego11, Majestic-12 [Bot], trmns and 82 guests
