milad221
Script for Runnig interface
Sat Feb 25, 2023 9:50 am
Hi
I need a script in such a way that when the interface is out of run mode, it will be in run mode again with enable, and this script will be checked every minute.
mikrotik ver : 7.7
milad221
Re: Script for Runnig interface
Sat Feb 25, 2023 9:52 am
Sample code generated by ChatGBT:
/system script add name=check_l2tp source={
:local interface_name;
:foreach interface in=[/interface find type=l2tp-ethernet] do={
:set interface_name [/interface get $interface name];
:if ([/interface get $interface running]) do={
:put ("L2TP Ethernet interface '$interface_name' is already running.");
} else {
:put ("Starting L2TP Ethernet interface '$interface_name'...");
/interface enable $interface;
BartoszP
Sat Feb 25, 2023 10:54 am
Sample code generated by ChatGBT:...
Really? Can't believe it ...
milad221
Sat Feb 25, 2023 11:10 am
yes but don't work
Reason: removed excessive quotting of preceding post; be wise, quote smart. lines of quote, 1 line of post.
BartoszP
Sat Feb 25, 2023 11:55 am
So what are you posting this nonworking code for? Just to promote chat?
nichky
try this:
:global ifstatus
:if ([/interface ethernet get ether1 running]=true) do={
	:put "running"
	:if ($ifstatus="down") do={
		:put "changed to up"
	:set $ifstatus "up"
} else={
	:put "not running"
	:if ($ifstatus="up") do={
		:put "changed to down"
	:set $ifstatus "down"
milad221
Sun Feb 26, 2023 10:43 am
try this:
:global ifstatus
	:put "running"
	:set $ifstatus "up"
} else={
	:put "not running"
i running l2tp ethernet
change ethernet to l2tp ethernet ?
milad221
Sun Feb 26, 2023 11:31 am
This script worked with a few changes, but if ether is not running, will it automatically run again?
milad221
Sun Feb 26, 2023 11:54 am
try this:
:global ifstatus
	:put "running"
	:set $ifstatus "up"
} else={
	:put "not running"
This script was tested. When Ether exits the run mode, it does not run again, even though the script counts.
rextended
Sun Feb 26, 2023 5:23 pm
stop spam quotes everywhere.
It's ridiculous, simply modify last post if you want add something to yourself.
clean up the mess you made in previous posts: delete everything quoted.
Users browsing this forum: No registered users and 38 guests
