Spiralout615
Bridge Vlan Filtering, Home/Guest for Unifi AP
Sun Feb 26, 2023 1:23 am
I have a HexS that I am trying to replace my OpenWRT router with. I have a Home and Guest VLAN, home is Native ID1 and Guest is ID 3. Port 2 of the HexS will go to an 8 port unmanaged switch which has home LAN devices plugged in and a Unifi AP. The Unifi AP has a Guest SSID (VLAN 3) and a HOME SSID (VLAN 1). I have tried to replicate my config in the Open WRT within Router OS, but as soon as I enable Bridge VLAN filtering I lose access (Safe Mode) and then it resets my config. What am I doing wrong? The tagging and untagging and PVIDs doesn't seem to align with OpenWRTs use of them. Config Below:
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
[admin@MikroTik] > export hide-sensitive
# jan/02/1970 01:38:23 by RouterOS 7.7
# software id = 8GPG-EPZ6
# model = RB760iGS
# serial number =
add admin-mac=DC:2C:6E:86:03:9B auto-mac=no comment=defconf name=bridge \
protocol-mode=none
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN_AP
set [ find default-name=ether3 ] name=ether3-LAN
set [ find default-name=ether4 ] name=ether4-LAN
set [ find default-name=ether5 ] name=ether5-LAN
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add interface=bridge name=VLANGUEST3 vlan-id=3
add interface=bridge name=VLANHOME1 vlan-id=1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=HOMEPOOL ranges=192.168.69.100-192.168.69.254
add name=GUESTPOOL ranges=192.168.70.100-192.168.70.150
add address-pool=HOMEPOOL interface=VLANHOME1 lease-time=4h name=HOMEDHCP
add address-pool=GUESTPOOL interface=VLANGUEST3 name=GUESTPOOL
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2-LAN_AP
add bridge=bridge comment=defconf interface=ether3-LAN
add bridge=bridge comment=defconf interface=ether4-LAN
add bridge=bridge comment=defconf interface=ether5-LAN
add bridge=bridge comment=defconf disabled=yes interface=sfp1
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=\
ether2-LAN_AP,ether3-LAN,ether4-LAN,ether5-LAN vlan-ids=1
add bridge=bridge tagged=bridge,ether2-LAN_AP,ether3-LAN,ether4-LAN,ether5-LAN \
vlan-ids=3
add comment=defconf interface=ether1-WAN list=WAN
add address=192.168.69.69/24 interface=VLANHOME1 network=192.168.69.0
add address=192.168.70.1/24 interface=VLANGUEST3 network=192.168.70.0
/ip dhcp-client
add comment=defconf interface=ether1-WAN use-peer-dns=no
add address=192.168.69.0/24 comment=defconf dns-server=9.9.9.9,1.1.1.1 gateway=\
192.168.69.69
add address=192.168.70.0/24 dns-server=9.9.9.9,1.1.1.1 gateway=192.168.70.1
set allow-remote-requests=yes servers=9.9.9.9,1.1.1.1
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
Thanks !
Users browsing this forum: Google [Bot], GoogleOther [Bot] and 23 guests
