valnik
Passthrough USB or mounts to container
Sun Feb 26, 2023 3:20 pm
i have installed proxmox_backup_server in container /docker/ and i would like to passthrough usb storage or directory from this storage to container /to do backups/.
Is it possiblle?
Thx in advance.
Petr
Amm0
Re: Passthrough USB or mounts to container
Sun Feb 26, 2023 7:31 pm
Not directly. But if the USB disk found by RouterOS running the container, it can be added in /container/mounts.
But USB is not accessible to the /containers, on any platform, today.
jaxed7
Sun Sep 10, 2023 7:53 am
@valnik Would be so kind and share your setup config for the Proxmox backup server container? since I want to install the same thing and been trying this image "https://github.com/ayufan/pve-backup-se ... ckerfiles/" and ran into various problems for volumes and etc. (I'm using the pre-compiled and hosted at https://hub.docker.com/r/ayufan/proxmox-backup-server)
P.S. I want to have all the mounts and etc on the disk1 (since it's a x86_64 router with only one disk that got 512GB of size :D so everything will be where ROS is also installed)
Users browsing this forum: No registered users and 5 guests
