Bolo
hap ac2 low speed with 1gbps fiber
Sun Feb 26, 2023 10:52 pm
Hi there,
I'm pretty new on the forum, networking and Mikrotik products as well.
I decided to start learning routeros from scratch but as a first thing I'd like to use a hap ac2 as main home network router. I have 1Gbps FTTH and the hap is connected to the ONT.
I set the pppoe client up on ether1, basic firewall config (the basic one from mikrotik) and the other interfaces are bridged.
Now, I just can get up to 300Mbps upload speed instead of something close to 1 Gbps. By reading the specs and speed test I assumed hap ac2 was capable to manage such 1Gbps speed with a basic firewall rules set.
Config down below.
Any suggestion or explanation on how I can't get the full speed?
# feb/26/2023 21:49:05 by RouterOS 6.49.7
# software id = 35QG-FUDM
# model = RBD52G-5HacD2HnD
# serial number = HCY081Y2GKN
add admin-mac=18:FD:74:77:0C:48 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-770C4C wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    ap-bridge ssid=MikroTik-770C4D wireless-protocol=802.11
/interface vlan
add interface=ether1 name=vlan_fibra vlan-id=835
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan_fibra name=pppoe-fibra \
    password=*********** user=*************
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=10.10.10.10-10.10.10.100
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=10.10.10.254/24 comment=defconf interface=bridge network=10.10.10.0
add address=10.10.10.0/24 comment=defconf dns-server=10.10.10.254 gateway=\
    10.10.10.254
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.10.10.254 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat out-interface=pppoe-fibra
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=RouterBolo
/tool mac-server
/tool mac-server mac-winbox
liviu2004
Re: hap ac2 low speed with 1gbps fiber
Mon Feb 27, 2023 12:48 am
Do you test on cable, wifi, 2g or 5g? You might want to drop dns open resolver, why do you need that? To be part of ddos attacks? You’re one of the bad guys?
Moba
Mon Feb 27, 2023 7:31 pm
There's something wrong if you tested over ethernet. This device can handle a lot more bandwidth with Fasttrack unless the CPU is pegged doing other things. Reset the device, connect a single computer over ethernet and monitor the CPU cores while testing. Anything that can't be handle by the switch has to be processed by the CPU (incl. NAT). If it still doesn't work and the CPU looks fine, something else is probably wrong between the ONT and the router.
Bolo
Wed Mar 01, 2023 10:21 am
Dear all,
thanks for the kind replies.
About the DNS attacks...I'n not one of those guys, just set the default config and added the pppoe connection as a first step. My first target is to replace the terrible router provided by the ISP. I also have another cheap routerboard on which I'll be start learning and testing. If something is wrong in the config, please tell me what to remove and, maybe, why and I will also read documentation.
I found out that the usb-nic I was using for testing was somehow limited to around 350Mbps even if it should be a 1Gbps one.
In tried with another one and I get speed up to 930, 935 Mbps which is very reasonable for the 1 Gbps fiber.
I now have another problem right now. The WiFi speed is very slow, up to 100Mbps with both 2.4 and 5 GHz. I can't find any capping configuration but I may absolutely be wrong. Do you have any suggestion?
Thanks again so much!
erlinden
Re: hap ac2 low speed with 1gbps fiber  [SOLVED]
Wed Mar 01, 2023 10:27 am
Your config is crappy in regards to wireless settings. Please use the search option in this forum (and search for user bpwl), you will find tons of optimizations. Default config just works...but wireless requires a lot of finetuning.
Bolo
Wed Mar 01, 2023 11:30 am
I'm gonna do that! :)
Users browsing this forum: GoogleOther [Bot] and 86 guests
