PeterXC
hAP ax3 CPU temp and performance  [SOLVED]
Tue Feb 28, 2023 11:28 am
What is a typical hAP AX3 CPU temperature on idle and under WiFi load?
In my case, on idle, I have 62 deg C, and under iperf3 load, it gets to 72 deg C, CPU load 25-30%
Still, my max load on ax or ac is below 800Mbps, typically 300-500Mbps in short range
I wonder, is it normal, or maybe my heatsink on the CPU is broken or not well connected?
Edit: my cabinet env: temp: 24 deg C, humidity 42%
Raspberry Pi CPU is 34-38 deg C depending on load, over 30deg cooler than AX3 🤔
alibloke
Re: hAP ax3 CPU temp and performance
Tue Feb 28, 2023 11:36 am
Mine is sitting at 43 degrees idle right now, but my room temperature is currently 15 degrees.
Rox169
Tue Feb 28, 2023 1:36 pm
Mine is 49 celsius but only as AP. Mine AX2 is 59 celsius, with loads settings...
PeterXC
Thu Mar 09, 2023 6:33 pm
Sent it back to the Service, it is broken and will be replaced
chechito
Thu Mar 09, 2023 7:30 pm
state of art chips work well up to 90°C or even more without problem
please do not create duplicate topics
PeterXC
Thu Mar 09, 2023 7:55 pm
State of art chips can actually perform.
Please don’t spam closed topics
rimjobbob
Sun Apr 16, 2023 9:23 am
Was the temperature an issue? I recently set up my ax3 and as ap only with 3 idling clients and a CPU load of 1% at 19°C it sits at 53°C. Should I be concerned?
dark77
Tue Apr 25, 2023 6:52 pm
It seems ok to me.
radlovsky
Sun Apr 30, 2023 1:39 pm
Hello Peter. Has your device been replaced? Is it any better with the new one?
PeterXC
Wed May 03, 2023 7:12 pm
It helped for temperature, new device is 10-20 deg cooler. It hasn’t changed the Wi-Fi performance.
I made my piece with poor Wi-Fi performance.
soonwai
Fri May 05, 2023 8:48 pm
My ax3 is quite consistent at 20C above ambient when the ceiling fan is on and 25C above ambient when the fan is off.
CPU load is fairly low. Mostly at 1-2% with the occasional spike to 6%. It's running as an AP, switch and 3 containers (1 of which is only active every 60 days for a miniute.)
Currently (1:50am) it's at 49C. Room temp is 29.5C. Ceiling fan on.
Temps for RB5009, hAP ax3, hAP ax and RB2011.
Also have an hAP ac2 but no temp sensor.
Rox169
Sat May 06, 2023 9:21 am
My HAP AX3 only as AP had 50° now use it as gateway with many settings and it has 62° in closet and without any load.
The same was with AX2, only AP around 50° as gateway around 60 without load in closet
Users browsing this forum: andriy132, Bing [Bot] and 13 guests
