how find active route for DST ip ?
"ip route/print where dst-address=172.28.250.32/32" not workking if you are not have the same route
is there an analogue of the rtlookup command in extreme XOS?
thanks, that's helpful. but not quite what I asked. This shows all routes that match the parameter. And how to understand which one is active for this ip dst?
and on a small number of routes it still works, but if there is a fullview or several of them, then the response time is huge. I didn't get a response in 10 minutes.
On ROS 6 and fullview its imposible. will have to wait indefinitely. But if you have not so many routes - its works. but this is not my case, unfortunately.
