akira463
Foreach data string holding
Tue Feb 28, 2023 7:27 pm
Hello master, Im here again with another question.
I do want to write all ppp secret details txt file format, The problem is, when i run my code, it only register one name , what could be wrong?
:local filedata ""
:foreach i in=[/ppp secret find] do={
  :local name [/ppp secret get $i name]
  :local password [/ppp secret get $i password]
  :set  $filedata ("$name:$password\n")
/file print file="ppp-secrets.txt"
:delay 2
/file set "ppp-secrets.txt" content=$filedata
rextended
Re: Foreach data string holding
Tue Feb 28, 2023 9:28 pm
You do not keep previous values....
set is... set, not "add at the end"
set x a
set x b
set x c
and at the end x is only c, not "abc"
Please write code correctly, no $ on variable name after global, local or set
:local filedata ""
/ppp secret
:foreach i in=[find] do={
  :local name     [get $i name]
  :local password [get $i password]
  :set filedata "$filedata$name:$password\r\n"
:delay 2s
akira463
Wed Mar 01, 2023 2:52 am
Thankyou for the reply sir, but the problem sir still insist, it does not work :( . i also tried in telegram, but still i got no reply
here's my code
#telegram
    :local botToken "XXXXXXXXX:XXXXXXX"
    :local chatID "-XXXXXXX"
:local filedata ""
/ppp secret
/tool fetch url="https://api.telegram.org/bot$botToken/sendMessage?chat_id=$chatID&text=test $filedata"
rextended
Wed Mar 01, 2023 11:39 am
The script on post #2 for me works, but how many items are?
The file created on this way can not exceed ~4000 Bytes...
On terminal, THIS work? (do not omit parenthesys { })
:local filedata ""
/ppp secret
:put $filedata
You can not send the data directly to telegram if you do not convert it to UTF-8 + URLencode....
And probably GET on fetch can not support more than 256 characters (not tested)
akira463
Wed Mar 01, 2023 4:12 pm
Yes sir, on terminal it works, but when i create file.txt, it does not.. what could be the solution ?
here's the result after running the script, it just log the file tree
akira463
Wed Mar 01, 2023 5:07 pm
Thank you sir, It works now, but the problem the limit of the data must only 4000bytes as you said, anyway, thankyou so much!!!
rextended
Wed Mar 01, 2023 5:54 pm
If are not soo much, consider this.... remove unused start letters on your secrets, or add numbers or symbols you use...
/ppp secret
:foreach l in=[:toarray "A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V,W,X,Y,Z,a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z"] do={
    :local filedata ""
    :local letter $l
    :local filename "ppp-secrets-$letter.txt"
    /file print file=$filename
    :delay 2s
    :foreach i in=[find where name~"^$l"] do={
    /file set $filename content=$filedata
akira463
Thu Mar 02, 2023 5:10 pm
Thankyou again sir. Youre the best!!! 😁😁😁
Users browsing this forum: No registered users and 61 guests
