Joe1vm
CAPSMAN wifiwave2 - multiple CAPs
Tue Feb 28, 2023 9:28 pm
I am trying to manage 3 CAPs (ax) via CAPSMAN (ROS v7.8). Each CAP should have the same "local" and "guest" configuration, but set on different channels in 2.4Ghz and 5GHz bands. So, 12 CAP interfaces in total.
Up to now I found that the only way how to manage it is to create 12 configurations, (2 combination of security and 6 channels) which are provisioned via 6 rules linked with mac address of CAP WIFI interfaces.
There were possibility in the previous CPASMAN to create (by copy) "static" CAP interface with user defined name and defined channel, which was provisioned by simple general master/slave provisioning rule(without channels defined). The name and channel was retained even if the new provisioning was done.
Unfortunately, I did not find the way how to do it in wifiwave2. Even if the provisioning action is set to „create enabled", then the CAP interface names changed, channel added next re-provisioning changes the name to default and remove the channels.
Please, any idea?
Thanks.
Users browsing this forum: pav5 and 68 guests
