amin1356
Script for OVPN users
Wed Mar 01, 2023 4:06 pm
I need Script on my MikroTik server for checking connected OVPN users and remove any OVPN users that its uptime more than 1 Minute but Tx is 0.
Something like this:
int ovpn-server remove [find uptime>00:01:00 Tx=0]
but above script doesn't work!
anyone can help?
Thanks,
rextended
Re: Script for OVPN users
Wed Mar 01, 2023 7:59 pm
Tx not exist.
amin1356
Wed Mar 01, 2023 8:09 pm
Tx not exist.
What about "Tx Bytes" ?
rextended
Wed Mar 01, 2023 8:12 pm
I do not use OVPN.
On terminal paste this, using one OVPN real interface name
:put [/interface get <ovpn-test>]
Search on results how the wanted field are called, for example "...;tx-byte=541654;...".
Replace tx-byte on following script with the corect name:
probably working code
/interface ovpn-server remove [find where ((uptime > 00:01:00) and ([/interface get $name tx-byte] = 0))]
If you use this on scripts, DO NOT DECLARE any variable called "name" on the script...
I can not test it, so no warranty that works,
but is nice if you write is work or not for other users.
rextended
Wed Mar 01, 2023 8:46 pm
Tx not exist.
You test the script?
amin1356
Wed Mar 01, 2023 10:27 pm
I do not use OVPN.
[admin@MikroTik] > :put [/interface get <ovpn-amin1356>]
.id=*f00e1b;actual-mtu=1400;disabled=false;dynamic=true;fp-rx-byte=0;
fp-rx-packet=0;fp-tx-byte=0;fp-tx-packet=0;last-link-up-time=mar/01/2
023 23:19:14;link-downs=0;mtu=1500;name=<ovpn-amin1356>;running=true;
rx-byte=594633;rx-drop=0;rx-error=0;rx-packet=3255;tx-byte=11926821;t
x-drop=0;tx-error=0;tx-packet=10736;tx-queue-drop=0;type=ovpn-in
it seems there is no "uptime" (online duration) field!
rextended
Wed Mar 01, 2023 11:28 pm
It doesn't matter, matter only the existance of "tx-byte".
You don't have to change that parameter there, try the script (if any is blocked, obviously do not return anything if all is ok...)
amin1356
Wed Mar 01, 2023 11:46 pm
with above command nothing happened but the following command seems to remove any user with tx-byte=0 :
/interface ovpn-server remove [find where ([/interface get $name rx-byte] = 0)]
I need more test for the exact result ....
rextended
Thu Mar 02, 2023 12:24 am
I can not test it because do not have OVPN ,as I already wrote,
but you put Rx- on script not Tx-...
amin1356
Re: Script for OVPN users  [SOLVED]
Thu Mar 02, 2023 6:50 am
Thank you @rextended,
Solved my problem.
Users browsing this forum: No registered users and 24 guests
