Warrentyexpired
Fairly fresh setup. Need help forwarding ports to a reverse proxy.
Wed Mar 01, 2023 4:49 pm
Here is my setup. I have a Netgear cable modem connected to ethernet port 1 of my MikroTik hAP ac2 router. That them goes from ethernet port 2 to a netgear unmanaged switch. Then from the switch it branches off to my my AP, my Tv, and my home server. Here is my Hap 2ac config. It's basically just the default config.
# feb/28/2023 14:26:05 by RouterOS 6.49.7
# software id = TPJJ-GKHK
# model = RBD52G-5HacD2HnD
# serial number = HD20xxxxx
add admin-mac=18:FD:74:8F:0F:EF auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country="united states" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=NachoWifiSucker \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=NachoWifiSucker5 \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa2-pre-shared-key=<PASSWORD>
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.100 client-id=\
    ff:d4:f5:37:c5:0:1:0:1:2b:26:27:0:fc:4d:d4:f5:37:c5 mac-address=\
    FC:4D:D4:F5:37:C5 server=defconf
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system clock
set time-zone-name=America/New_York
/tool mac-server
/tool mac-server mac-winbox
My server is running various services like proxmox, nextcloud, photoprism, and Nginx reverse proxy. I would like to be able to access nextcloud and photoprism from the internet. I have my own google domain that is pointing to my public ip address. I can ping my domain and its resolving to my public ip address. Now I need help forwarding traffic to the Nginx reverse proxy. Which Im assuming means I need to forward ports 80 and 443 to the machine running the reverse proxy. I had this all setup and running properly on a digital oceans droplet vps to test setting it up outside my home network.
I need some guidance on what to do next. I've done port forwarding before, but not on a router this sophisticated.
Reason: Use proper tags: quote to quote, code for code - keep forum tidy
baragoon
Re: Fairly fresh setup. Need help forwarding ports to a reverse proxy.
Wed Mar 01, 2023 8:54 pm
/ip firewall nat add action=dst-nat chain=dstnat dst-address=WAN_IP dst-port=80,443 protocol=tcp to-addresses=LAN_SERVER_IP
Warrentyexpired
Wed Mar 01, 2023 9:26 pm
I don't have a static public IP address though. It changes every once in a while (months sometimes). Will I need to re-run the command every time it changes? Also will forwarding 80 and 443 interfere with any other devices on my network? I don't think it should, I just wanna make sure its not gonna mess with my wifes work laptop and there vpn.
mkx
Wed Mar 01, 2023 9:41 pm
It is fine to have DST NAT set up like this:
add action=dst-nat chain=dstnat in-interface-list=WAN dst-port=80,443 protocol=tcp to-addresses=LAN_SERVER_IP
WAN interface list is already used in firewall and NAT rules.
This setup has a gotcha: it doesn't work if you want to connect to WAN IP address (and have DST NAT working) from within LAN. Neither does the rule by @baragoon on its own (it needs another SRC-NAT rule), but the rule in my post can't be used in this case.
If DST-NAT rule is done properly (i.e. it's not greedy due to properly set dst-address or in-interface or some other selector properties), then it won't interfere with other traffic (e.g. access to web pages on internet from LAN).
Warrentyexpired
Thu Mar 02, 2023 2:12 pm
I'm gonna assume this is when to use a hairpin nat? I followed a youtube video that had me make an address list for LAN and WAN then set up port forwarding and a hairpin nat and that worked with opening a test 9000 port. I can access it via internet and internal network.
If you wouldn't mind could you explain what you mean by "not greedy"
This is what i did and got working for port 9000. I have it disabled at the moment because it was just for testing.
add action=dst-nat chain=dstnat comment="Open Port 9000" disabled=yes \
    dst-address-list=WAN dst-port=9000 protocol=tcp to-addresses=\
    192.168.88.102 to-ports=9000
mkx
Thu Mar 02, 2023 4:37 pm
I was commenting my own config example ... which avoids setting WAN IP address (you're saying it's dynamic albeit with low rate of changes) but comes with mentioned gotcha which indeed is about hairpin NAT.
Taking your rule and making it greedy ... also changed port to some very well known one to make the point:
add action=dst-nat chain=dstnat comment="Open Port 443" dst-port=443 protocol=tcp to-addresses=192.168.88.102
It will affect every connection which targets port 443 (HTTPS) regardless DST IP address ... which means all internet servers as well. And that's what I call "greedy" rule.
You may get away with greedy rule for a non-standard port (e.g. 9000) because LAN users normally won't try to access that port on WAN side. But if they will, they'll have problems with that particular WAN server and it would not be trivial to pinpoint the problem as being caused by DST NAT rule ...
So yes, your example is "not greedy" ... but has problem that you have to maintain the "WAN" address list. If you can do it automatically (e.g. script run by scheduler every 2 minutes which takes actual WAN IP address and adds it to WAN address list with timeout set to say 10 minutes so that obsolete entries get removed automatically) that's fine, it would get stale if you had to update it manually. So if you will update WAN address list automatically, this is IMO fine solution and allows pretty easily to implement hairpin NAT.
Warrentyexpired
Sat Mar 04, 2023 6:50 pm
Thanks for the help mkx! I have forwarding working and my reverse proxy is doing its thing. Been running for 2 days and no issues with any other device on my network. Next step is to figure out how to script adding the Wan address to the address list when it eventually changes. Thanks again!
baragoon
Sat Mar 04, 2023 7:53 pm
Enable ip cloud and add your xxxxxxx.sn.mynetname.net to address list
Users browsing this forum: sutrus and 22 guests
