/ip firewall mangle
add action=mark-connection chain=input comment=LT_conn_mark connection-mark=\
no-mark in-interface=pppoe_LT new-connection-mark=LT_conn passthrough=yes
add action=mark-connection chain=input comment=DX_conn_mark connection-mark=\
no-mark in-interface=pppoe_DX new-connection-mark=DX_conn passthrough=yes
add action=mark-routing chain=output comment=to_LT connection-mark=LT_conn \
new-routing-mark=to_LT passthrough=yes
add action=mark-routing chain=output comment=to_DX connection-mark=DX_conn \
new-routing-mark=to_DX passthrough=yes
add action=masquerade chain=srcnat comment=NAT_DX out-interface=pppoe_DX
add action=masquerade chain=srcnat comment=NAT_LT out-interface=pppoe_LT
add action=dst-nat chain=dstnat comment="port forwarding 5900" dst-port=5900 \
in-interface=pppoe_LT protocol=tcp to-addresses=223.255.255.10 to-ports=\
5900
in-interface=pppoe_DX protocol=tcp to-addresses=223.255.255.10 to-ports=\
5900
add action=dst-nat chain=dstnat comment="port forwarding 80" dst-port=80 \
in-interface=pppoe_LT protocol=tcp to-addresses=223.255.255.2 to-ports=80
in-interface=pppoe_DX protocol=tcp to-addresses=223.255.255.2 to-ports=80
add action=dst-nat chain=dstnat comment="port forwarding 22" dst-port=22 \
in-interface=pppoe_LT protocol=tcp to-addresses=223.255.255.246 to-ports=22
in-interface=pppoe_DX protocol=tcp to-addresses=223.255.255.246 to-ports=22
I think I've figured out where my trouble spots are, I set up dual isp carriers and set up a routing policy to go in and out from wherever. I think the point of failure should be here to cause the failure of different carriers pinging each other with different IPs. After setting the policy from where to enter from where to exit, how can I add a policy to set different carriers to ping through?I dont play the game of chasing and as the config usually is not best parsed but consumed whole, for understanding, snippets hold no interest.
