Toby7
auto upgrade/upgrade package source not working
Sat Mar 04, 2023 12:07 am
I want to get the auto upgrade feature running on my mikrotik devices. There is the server 10.1.224.254 (rb4011) and a client 10.1.224.32 (hex poe). The client is able to ping the server. I did set the upgrade package source on the client as 10.1.224.254 with admin login data (to ensure that permissions are not an issue). Both devices are running ROS 7.6. Upgrade file routeros-7.8-mipsbe.npk is available as a file on the server.
Now when I check the available packages by clicking refresh on the client no data is visible. Any ideas? On which protocol is the file transfer based? Does it need any /ip services?
I did harden both devices so maybe I have disable some feature which is needed. Thanks for the support.
Regards Toby
Users browsing this forum: LdB, nocivo, toto4ds and 118 guests
