clambert
Uneven MPLS traffic between CPUs
Sat Mar 04, 2023 5:39 am
Hi everyone, we are seeing a particular behavior with incoming MPLS (L3VPN) traffic on the RB1100AHx4 and CCR2004-1G-12S+2XS running ROSv6 (6.48.6 long-term). In both devices the incoming traffic is completely handled by CPU 0.
In the CCR2004 we have discovered that if the MPLS interface is a VLAN interface, then the traffic is evenly balanced between CPU 0 and CPU 2 (in the RB1100 it does not make any difference).
Has anyone experienced this behaviour? And if that were the case, have you been able to solve it somehow?
clambert
Re: Uneven MPLS traffic between CPUs
Wed Mar 22, 2023 1:06 pm
Looking for information that can help us understand why this behavior occurs we have found the following information:
Flow/Packet steering
● RouterOS uses Receive Flow/Packet steering to assign incoming traffic to a specific CPU core/thread, based on the hash value.
● The hashing process can be:
– Hard-coded in the hardware.
– Configurable in the hardware.
– Implemented in the interface driver.
● Receive flow/packet steering will try to keep single TCP stream bound to single CPU core/thread as long as possible.
Reviewing the IRQ behavior in a RB1100AHx4 it is verified that the imbalance in the CPU cores comes from the traffic sent from the Realtek RTL8367 Gibabit Switch. The traffic received on channel 0 (we understand that it is associated with CPU0) is two orders of magnitude greater than that received on the three remaining channels.
/system resource irq print
 4 ro 128 al-eth-switch0-0-rx-0          auto            3 171 711 696
 5 ro 129 al-eth-switch0-0-rx-1          auto               31 839 251
 6 ro 130 al-eth-switch0-0-rx-2          auto               17 488 979
 7 ro 131 al-eth-switch0-0-rx-3          auto               18 862 440
We believe the limitation is that RTL8367 in not able to distinguish the MPLS header and effectively hash it to send traffic to the CPU in a balanced way.
Users browsing this forum: No registered users and 36 guests
